Hey guys and gals,
I thought I would share some pics and process info from a recent detail of mine.
I was doing a full detail and when I arrived I found that the headlights on this 2002 Lexus RX330 were heavily oxidized and the owner was in a panic as new lights (which she was about to buy!) would be over $400!!!!
Luckily, I have enough Meguiar's products to detail a small army of vehicles, and I had just the solution!
I first started to soak my Meguiar's Unigrit 3000 grit sandpaper, and after about 30 minutes of soaking I did a light sand over the headlights. Of course, I taped everything off around them first! Here's a picture that was intended to show my wet sanding on the front bumper (Also suffering from severe oxidation), but you can see the tape and the pre-polishing condition of the headlights:
and another...
Here is a direct before shot, which honestly makes it look about 10x better than it did in person! :
After I did the 3,000 grit wetsanding I wiped them down to make sure the sanding was evenly applied, and then I got my Makita, and a 4 inch Orange polishing/cutting pad and attacked the sanding marks with some Meguiar's #86 S010 Cut and Polish Cream.
WOW! This stuff rocks! If you do not have it, you need it. I enjoyed it so much on the headlights I used it as well on the bumpers where I had to wet sand and was incredibly pleased with the results.
Just to be safe, and also out of curiousity I got out a 4 inch white polishing pad and some Meguiar's PlastX for a final step on the headlights. Granted, they already were very clear and it wasn't really "needed" per se, I think it did add some additional clarity. Well, I'll let you be the judge...the picture speak for themselves (And to me they say, "Meguiar's products rule!
And of course, here are my after shots!
Comments? Tips? Suggestions?
and another...
