I just bought some and poured some between my fingers. When I rub between my fingers, I don't feel any grit at all. It has a lotion consistency, greenish, pleasant mild smell, but no gritty feel. Maybe I'll set the bottle upside down overnight before I try it tomorrow, in case all the grit is at the bottom? I found it accidentally at the auto parts store, laying on its side behind some other brand of cleaner. It was the only bottle they had, leaving me wondering how long it was lost there and if it's past it's use-by date, but I don't see any date on the bottle. I saw rave reviews of it on another forum is why I bought it. thanks in advance
Shouldn't Plast-X have a gritty feel?
Re: Shouldn't Plast-X have a gritty feel?
It has a very very mild abrasive so feelng it between your fingers doesn't happen. As far as shelf date I don't think it has one. The only way it would have a problem is in extreme heat or cold the chemicals may seperate.
Give it a good shake and work it in until the diminishing abrasives are gone and your good to go.01 Tacoma 4x4 X/C V6 Imperial Jade
"Oh, oh Marty, here's you keys. You're all waxed up, ready for tonight"
Biff Tannen
I haven't noticed any abrasive feel at all. It's not "rocks in a bottle", it's a polish with diminishing abrasives. No grit in it...if you want grit you can take some off the ground lol. Like ramphonic said, give it a good shake and work it in. You'll probably be happy with the results.Lydia's Mobile Detailing
2007 Honda ST1300 - Silver
Originally posted by WB1 View PostI just bought some and poured some between my fingers. When I rub between my fingers, I don't feel any grit at all.
Check this thread out,
The words Clean and Cleaning as defined by Meguiar's terminology
And if you're new to Meguiar's, you might find something that interests you here,
As long as the contents haven't frozen then it should be fine to use, just shake well before starting.
PlastX is the bomb. I've used it to maintain my Neon headlights and restore my Yukon headlights and give the tailights on my Yukon a new breath of fresh air. I love it.
Thanks for the responses. One of my headlights on this '89, the original headlight, is crystal clear, almost new looking. The other one I bought at a junkyard some years ago to replace the other original that was smashed in an accident. This junkyard one is very cloudy and has a very weak beam. Looks like I'll have to use something more aggressive on the cloudy one before finishing it w/Plast-X.
Originally posted by WB1 View PostLooks like I'll have to use something more aggressive on the cloudy one before finishing it w/Plast-X.
You don't know what you can do until you try.
Give the PlastX a try and use a little piece of terry cloth towel to apply it. Put some passion behind the terry cloth and rub pretty hard. At a minimum you should restore clarity and that may be all you need and/or want for your headlight.
Give it a shot.
AaronPhilippians 2:14 - Do all things without grumbling or questioning,
I use plastx on almost every detail I do. Awesome product by all means! Its probably on the list of products that continue to 'WOW' me.Current Jeep: 2004 Jeep Liberty with stuff
Originally posted by Mike PhillipsLive on the edge... try something new, try NXT Tech Wax 2
Originally posted by BlueLibby04 View PostI use plastx on almost every detail I do. Awesome product by all means! Its probably on the list of products that continue to 'WOW' me.
I want to try some on a damaged plastic but again I don't. I don't want it to be mine!Removing stress & swirls one car at a time!
PlastX is some WONDERFUL stuff. My gf's '99 Corolla has these black plastic side view mirrors on them, and they've been a hazy/scratched plastic look ever since she bought it used.
Well, the other day, I thought I'd give PlastX a try on the mirrors, since they were pretty scratched up and certainly couldn't get any worse by me working on them.
I put some PlastX on a clean terrycloth towel, did some really LIGHT polishing with the cloth (not even half as much as I would do when I use ScratchX to try & get a scratch out) and they came out looking better than I'd EVER expected. It's amazing how well the mirrors responded! I wish I'd thought to get a before & after, but I completely forgot to do so...Oh well, live & learn; I'll do it for next time.
Maybe if I can convince one of the guys at work that his headlights are really bad off (and they are) I can show a comparison of before & after on his headlights.
This is a half tested area I did with Plast-X. It's worked on everything I've tried it on with great results.
Jesse
www.ShineTechAutoDetail.com
Facebook www.detailing.com
