Anyone detail the engine of an 05 Mustang or 05 Impala?
  • Anyone detail the engine of an 05 Mustang or 05 Impala?
    Hi all,
    I'd like to clean the engine bays of both of my cars this summer and I was just wondering what I need to cover up before spraying with water? I love cars but I'm not mechanically inclined so I want to make sure I don't cause a problem. I could probably get pix if you want.
    Also would Meguiars engine degreaser and maybe the dressing be all you need or do you need other products to do it properly as well?
    Re: Anyone detail the engine of an 05 Mustang or 05 Impala?
    Also, the impala has a dirty as heck engine bay from 74,000 miles of driving so for that I know I'll need the super degreaser I'm guessing, but my mustang is a pleasure car with only lite dirt on the engine. Has anyone used that new Meguiars spray engine cleaner thats a new product this year? Would that be good just for cleaning light dirt or should I stick to the degreaser?
      when I was at the sacramento auto rama I talked to one of the megs sales reps he sead that the new engine cleaner was pritty mild but I have not tried it, I think it would work on your mustang, whare the buld up would not be as bad.
      for the impala if its like my engine bay I think super degreser is your best bet.
      2008 Mazda CX-9 (WIFE'S)
      1995 Ford F150 XLT (MINE)
        I have an 07 mustang and I always wait till it cools down then just cover your alternator up with a grocery bag and your distributor too. Then I rinse the engine down quick with a small amount of water. Spray the engine down with a degreaser of some kind. Use a brush to get all the dirt then rinse the engine off being careful not to use a bunch of water. Then if you want spray the entire engine bay with protectant and then start your car and wash the exterior of the car and then after you have washed your open the hood back up and touch up any little spots you might have missed. Hope that helps !
          ^ Like they said make sure the engine is cold and cover all electrics.
          I like using the expandable food bags to cover starter/alternator/battery etc.
          Mist with 1:1 simple green or if it's real bad an engine degreaser may be needed.
          Then as long as the electrics are covered "lightly" mist with water to remove cleaners.
          Merlin
          https://AMiracleDetailing.com
          Facebook - YouTube - X - Instagram​​
            I do about one or two engine washes a month and have never covered anything with plastic. Modern wiring connectors are pretty well sealed anyway but you obviously don't spray high pressure water directly at them. I just go to a self service car wash and bring a can of engine degreaser like Gunk. No need to let the engine cool, the instructions even say to warm up engine first. Then spray the engine, engine compartment as well as the underside of the hood with the Gunk. Depending on how dirty the car is, you may need very little Gunk, up to maybe a third of the can. Let it soak 5 minutes then blast it with the high pressure hose on the soap setting, then finish off with straight water.
