Steps to detail my engine
  • Steps to detail my engine
    Guys i would like to have the steps to detail my engine
    I have APC and HYPER DRESSING.
    assume that i remove all the dust in the engine using water so what will be the next step, beside the tools that should be used
    Re: Steps to detail my engine
    What I typically do is:
    1. Cover up the fuse box and alternator in a plastic bag
    2. Get the hose on mist setting and mist down the engine
    3. Spray down with APC+ and let sit for a few minutes
    4. Scrub with brush
    5. Rinse with mist setting
    6. Blow dry with leaf blower
    7. Spray on Hyper Dressing and let sit and dry
    Remove swirls my friends.
      thanks
      In Step 5 which kind of brush do you use?
      In step 7 after I spray the HD just I wait till it dr dray ? Or I should dry it ?
        do u have any photos before and after?
          what I would like to ask also , should I spray the APC or APC + on the plastic part only or in all the engine parts?
          Also when I apply the hyper dressing is it only for the plastic part or all the engine part also?
            You should be able to apply the products on everything.
            Although it is silly to dress metal. Let Hyper Dressing sit for 15 minutes, then you with a terry towel dampened with Hyper Dressing and blot up the excess.
            Search around for pictures, they are here.
              I just use a soft bristled brush on the engine, and just spray the hyper dressing on and let it sit. Use APC + it has degreasers in it. Here are a few pics
                To tell you the truth, when it comes to brushes for engine detailing you need to get creative. You need to look around for any kind of brush will help you to scrub hard to reach areas as well as easy to reach areas.
                I've found the brushes that come with a household or garage dustpan work pretty good because the long bristles can get into hard to reach areas and lightly agitate the degreaser to help remove the built-up grime. It's got a long handle and a long row of bristles so it actually works pretty well.
                I have a pink kitty dustpan brush that I've used for this recently and it's actually worked really well even though it's not very Macho...
                Believe it or not a facilities brush actually works pretty good. It has a long handle and stiff plastic bristles on a strong loop of twisted wire that you can usually shape.
                Also, tinfoil comes in handy sometimes because you can easily form it to a shape and when you're done you can easily remove it and recycle it or dispose of it.
                For example, wrap a component with some plastic, now wrap it with tinfoil and scrunch the tinfoil around the plastic to cocoon it. Then just try not to blast it with a high power spray, (spray around it).
                Works pretty good, fast, cheap and easy.
                  A post of mine.
                  Roush Mustang Engine Detail
                  Originally posted by roushstage2 View Post
                  Total Time: 20 Minutes
                  Process/Products Used
                  Sprayed the warm engine down liberally with APC+ diluted 10:1
                  Let it sit for 5 minutes
                  [Scrub here if needed]
                  Sprayed off really good
                  Let the engine run for 5 minutes
                  Soaked up any excess sitting water
                  Sprayed Water Based Dressing undiluted over the entire engine bay, and let it sit for a couple of minutes
                  Wiped down the engine bay with a terry towel dampened with Water Based Dressing
                  Viola! Clean!
                  Of course, the pictures just don't capture the look of it in real life. Water Based Dressing is a definite good choice for under the hood.
                    Thanks all
                      Splash, check out the links to engine bay detailing in my Internet Resources for Detailing Newbs.
                      --Al Kimel
                        meguiars wheel spoke brush works superb for engine cleaning.
                          Here you go...recent post of mine of an engine detail with pics, products, and process:
                          We encourage MOL members to show off their latest before & after results. We also welcome "Work in Progress" Threads. For Enthusiasts or Professional Detailers
                          Hope it helps!
                            What confuses me is that I assume every vehicle's "exposed" electrical components are going to vary. The obvious are the alternator and fuse box. But, what about the battery connection cables?
                            I worry I might miss not covering something important and running into problems!
