Spring Detail (1st Phase): Engine Detail
  • Spring Detail (1st Phase): Engine Detail
    I am breaking my spring detail of my Luthien (2007 Honda S2000) into several phases, all to be accomplished (hopefully) over the course of the next month. Today I tackled phase #1: the engine detail.
    I have never detailed an engine, and I confess I was more than a bit nervous. Yes, everyone says it's all very safe, as long as one takes the proper precautions; but what if I get it wrong? Anyway, today I decided to roll the hard six and do it.
    Here were my steps:
    1) Cover the alternator with a plastic bag and stuff a towel into the air intake.
    2) Spray down the front end with water from the hose. I understand this is desirable, just in case some of the degreasing solution should get onto the painted panels.
    3) Lightly spray the engine with water.
    4) Liberally spray the engine with Megs' APC+ (diluted approximately 8/1). In retrospect I think I might have sprayed a bit more than I did.
    5) Brush the areas I could reach. I used two different brushes: a soft tire brush I had picked up from AutoZone and a Swissvax detailing brush. I think I rushed this step. Next time I will slow down and try to do a more thorough job. I was concerned that the APC would dry out before I could get to it.
    6) Rinse the engine. I rinsed it fairly thoroughly. All the articles say to avoid the electronics, but heck if I could figure out where the electronics are. This was the nerve-wracking moment. Will the engine start?
    7) Remove plastic bag and towel. Start-up the engine and let it run for 5+ minutes. This is supposed to assist the drying. More importantly, I just wanted to know that the engine would run.
    8) Dry the areas of the engine I could reach with a towel.
    9) Spray the engine liberally with CD2 Engine Detailer. I picked up the CD2 at AutoZone.
    10) Per instructions, let the engine sit for 20 minutes with hood up.
    11) Per instructions, run the engine for 20 minutes with hood down. This is supposed to help the CD2 to set up and spread properly.
    During this time I gave the front end of my car an ONR wash.
    12) Open the hood and dry off with a towel any excess liquid.
    I then proceeded to finish the washing of the car, with special attention to door and trunk jambs. I later waxed these areas with Cleaner Wax.
    Finally I went looking for my camera. I did not take any "before" shots, as my engine looked fairly clean before I began. "Before" shots are so much more compelling and dramatic when the "before" is dirt and neglect disaster. Here are the "afters":
    I was pleased with this first attempt. I was especially pleased that my Luthien survived and lives to drive yet another day.
    I welcome your suggestions for improvement.
    Cheers,
    Al
    --Al Kimel
    Re: Spring Detail (1st Phase)
    I do not believe I have ever seen a cleaner engine. Great work. It looks fantastic.
      Very clean indeed!
        looks great Akimel, I like to use M40 as a dressing for my engine as it cleans/conditions nicely.
          Re: Spring Detail (1st Phase): Engine Detail
          Holy smokes, is that a new car? That is one CLEAN engine bay!
            I should have mentioned that in the beginning, as my first step, I warmed up my car for about a minute. I am beginning to think that I was wrong to warm up the car even a little. I had read on Autopia that one should do that, that it makes it easier to remove grease. Next time I will begin with the engine stone cold.
            --Al Kimel
              Hard to say... warming the engine might loosen some stuff, but also quicken the drying times elsewhere.
                Looks great Al!
                Only thing I would suggest is to maybe take off the gold cover and make sure no water got down in the recessed area for the plugs.
                Rasky
                Rasky's Auto Detailing
                  Egads! Take off the gold cover? That's more intimidating for me than hosing the motor!!
                  --Al Kimel
                    Nice work Al
                      I'm sure you are fine but on some older Honda/Acura motors I have seen water get down in there....of coarse we were using a pressure washer too.
                        A question for the experienced engine bay detailers: Should I have covered up the battery? I did spray it with APC+ and I did subsequently rinse it with the hose. Was this wrong or dangerous?
                        --Al Kimel
                          curious as well
                          2008 Toyota Corolla 5-spd
                          2005 Honda CRF250R
                          2002 kawasaki Ninja ZX9R
                            You may just want to watch the posts for any corrosion starting. If so, pick up a can of CRC Technician's Grade Battery Cleaner with Acid Indicator and spray the posts down, then just rinse with some water, ironically. Works quick and pretty dang well without any scrubbing too. Just did this on the Roush actually.
                              i just love a clean engine! congratulations!
                              as for the dressing, i prefer hiper dressing for the engine and all exterior plastics, M40 is watter soluted and wont las as long on the engine as hiper dressing. i clean my engine twice a year and its the dressing is still there.
