soon i will have my website done , until that i try to get the pages ready,one of them is "info" with some few details about paint correction. is not corrected of mistakes , but u got the idea , i need feedback .... i may miss something
PAINT CORRECTION
If your car care goal is to remove car finish imperfection / deeper defects you have to understand that after you do all this paint correction work on your car`s paint you'll have to take ownership of the car washing process or the scratches and swirlmarks will show up again. Let`s see more details about paint imperfections.
Swirlmarks - usually are minor small scratches that are visible in direct sun light . Swirlmarks are scratches in the clear coat or the exposed paint layer if one stage paint. Swirlmarks apear easy if the car is not wash right and the paint is not well maintained. A visit to the dealer with free car wash or automatic car wash that use touch brushes to remove dirt from car are the first places where your car gets swirl , also if the car is wash with improper tools and technique may demage the paint finish.
Holograms - appear when the car was attepted to be paint corrected and fail due the steps in brake down the compound stop , or on the paint surface wasn`t apply a finish compound . Usually when a part of the car was repainted and the finish didn`t fallow all the process to get the paint the last finish may end up with holograms. can be remove by using mid or finish compound
Scratches - most of scratches can be remove with buff/polish method, if are in the clear coat layer and not too deep in the car paint. If the nail goes in the scratch that means is too deep and need touch up paint or repaint the panel to be fix.
Oxidation – when the car is over exposed to weather conditions for a long period of time and doesn`t have any wax protection , the first paint layer start to change the color and loose the shine. the paint can be bring back to life by buff/polish tehniques.
Over spray - is a result of poor paint/repaint techniques , the result is uneven surfaces with paint drips or saggy looking paint finish. by wetsand the area and buff/polish the over spray can be remove and left behind an even smooth finish.
Orange peel - the finish clear coat is not even and looks like an orange peel , because of that the reflection in the paint finish is not clear. by using wetsand the orange peel can be remove and fallow with rotary buffing the paint can have a nice reflection.
Key marks / Chips / Deep scratches - touch up paint is needed when the scratch/chip are deep all the way to the metal or pass a good distance in the paint surface. Is a process more complex because are use more steps but with good results. if the scratch is too wide a prep and respray the area is need it. for a good result with touch up the fill in paint must pass the paint layer and is good if the fill in paint is apply in multiple coats.
Wetsand - is used to remove some imperfections like scratches, orange peel and leave after buff a clean mirror finish . wetsand cars are usually exotic /classic and show cars.
Most car owners don`t forget about their service due , like oil change but they forget about their paint maintenance , and end up with some of this imperfections...
PAINT CORRECTION
