Thanks both of you....Have in mind that i am working with a DA polisher...
Also is M105 available in Europe market??
i already bought #80 #83 #7 3 step deep cleaning system wheel brush,8006 pads,NXT2.0,Gold class liquid wax,Clay bar kit,plast X, Scratch X and some MF towels....
Also i would like to ask how safe are the engine cleaner,wheel cleaners and interior cleaners to use them as it is or if i have to put some water in them??
Engine cleaners, wheel cleaners and interior cleaners are safe when used according to manufactures directions and with common sense. Northing's fool proof so you need to do your research and after getting your products use them at the correct dilution levels and also do any research necessary before using them, for example try to find out if there are any components in the engine compartment that shouldn't get wet or sprayed with a degreaser or high pressure water.
If you're working on a specific make and model of a car, try to find a forum that's dedicated to that type of car and join their forum and then ask them what to be careful around.
