Whats the best way to remove paint over spray from aircraft paint? Would using a clay bar be enough?
Need quick advice
Re: Need quick advice
Originally posted by AeroCleanse View PostWhats the best way to remove paint over spray from aircraft paint? Would using a clay bar be enough?
Other than clay the only thing I can think of to remove over spray would be something like the Hi-Tech Body Sponge. I've never used a Body Sponge so I can't speak for how well they work. Here are some threads on the Sponge... http://forumarchive.meguiars.com/sea...body+sponge%22Scott
Originally posted by BlueZero View PostOther than clay the only thing I can think of to remove over spray would be something like the Hi-Tech Body Sponge. I've never used a Body Sponge so I can't speak for how well they work. Here are some threads on the Sponge... http://forumarchive.meguiars.com/sea...body+sponge%22
Originally posted by AeroCleanse View PostWhat would be the something else? Well this is a large King Air 300, so I'm only removing paint over spray from the effected areas, not the whole aircraft.
If that was still not removing all the contaminants I would try a paint cleaner #2 or cleaner/polish #80 although these typically are used for below suface defects. I have seen though, that by using products such as these, putting them on the paint surface and letting them sit for a little bit, but not dry, and then removing it softens up the above surface contaminent enough that it can be removed. When doing this it has been done by hand with either a terri cloth towel or foam applicator to put the product on and a terri or microfiber towel to remove it. Sometimes it has taken me multiple tries but it did come off.
That's not to say it will work every time but I have had some luck using that process.
