Professional Bottles Question
  • Professional Bottles Question
    I just recieved some product specific bottles with my recent order. I love them along with the sprayers. My question is...how do I use the dilution marks? I fill water up to the dillution mark correct? Then I add the product.
    My question is to what line do I add product to?
    Chris
    "Once a Meguiar's user...always a Meguiar's user!"
    1994 Accord
    Hi:
    Not sure it is correct put I always add product to the last external ring on the tappered section of the bottle. This leaves a small area for expansion.
    KTruck
    Make it Shine
      Hi williams22,
      The way the new secondary bottle work is you fill them with water first, to the dillution level mark of your choice and then add product using the hand pump.
      The idea is to get away from having your product foam up as you add water.
        Are you suppose to get a hand pump with your gallon then or do you have to order it separately? I bought a couple gallons, and got a couple bottles, but do I now have to buy a hand pump? If so, how much of it would I have to dispense to match the dilution ratios since I don't have a hand pump?
          I dont have a hand pump at the moment.
          On the bottles, I see how you are supposed to go upto the first set lines with water. But there is no clear marking on how high up your supposed to go with whatever product you want.
          So.. I am also wondering about this.
            I usually pour up to the top rib on the bottle that leaves a enough room that you don't over fill and spill over.
            I'll check and see if there is an exact level for accurate dilutions tomorrow.
