wheel and rim cleaner
  • wheel and rim cleaner
    What rim and tire cleaner is best for factory wheels. Can you post some pics because
    Don't forget to rev em high 2005 infiniti fx45, 2005 subaru outback sport se
    2000 ford ranger xlt, 2006 nissan maxima se
    Re: wheel and rim cleaner
    Car wash soap
    2005 Toyota Camry LE Phantom Grey Pearl
    2001 Toyota Corolla LE Silverstream Opalescent
    1996 Lexus ES300 Ruby Pearl
      that's what I thought and I use Hot Rims All Wheel cleaner.
        I use the Multi-Piece Wheel Cleaner a lot. I think it is suposed to be the most gentle one.
          you could use both of these, but the multi piece wheel wash seems to be the more gentle between the two...
          Introducing a safe way to clean delicate wheel and brake components. New Hot Rims Multi Piece Wheel Wash is a non-alkaline, non-acid formula designed to safely remove grime, grit and brake dust from all polished/unpolished aluminum,powder-coated, multi-surface or anodized wheels - also safe on all aftermarket brake components including calipers and rotors. Helps break down stubborn road residue with our Hot Rims unique foaming agents. Our Xtreme Cling™ foam is designed to cling vigorously to vertical surfaces and helps to lift and separate dirt from your wheels.
          The name says it all! Hot Rims All Wheel Cleaner is unlike any formula in the world for removing grime, grit and brake dust from all factory wheel surfaces. Remove stubborn road residue with Hot Rims' unique foaming agents, Our Xtreme Cling™ foam is designed to cling vigorously to vertical surfaces and break down stubborn road residue between your wheels and a brilliant shine! Safe for all factory, clear-coated and painted wheels.
            Originally posted by Mayur View Post
            Car wash soap
            I am with Mayur on this one, Meguiars does make some good wheel cleaners and they have a great selection but in my case I like to stay with Gold Class Shampoo and water.
            Brandon
            2007 Black Chevy Avalanche
            My Albums: Avalanche
              As others, car wash solution. If they're really dirty, I get the wheel brightener out and it never fails to amaze me with its power yet it's very gentle to the wheel itself.
              showroomglaze.net
                I like NXT wash on the wheels. Makes the painted ones shine really nicely. But of course I have a gallon of wheel brightner and I find out later I cant use it on polished rims Im gonna have to use it on the other two cars. Only problem is that Im afraid it might strip off any wax that might be on the wheels.
                  Absolutely will strip wax.
                    and when the dirt is stick to your wheel and soap does get it off
                    than you need to use a wheel cleaner right ?
                    or anny other ideas ?
                    alberto gorin
                    known as gorin002
                      I am with dupont on this one, they do wonders.
                      (\__/)
                      (='.'=) This is Bunny. Copy and paste bunny into (")_(") signature to help him gain world domination
                        If you wax your wheels, you will want to wash somewhat often so that soap and water will be all that is needed. After several washes, you could then clay/clean/wax etc again.
                        If it gets to the point that soapy water wont clean waxed wheels, then it is time for an actual wheel cleaner.
                          either have du pont.heard ****** wax was not so good
                          read from some user
                          alberto gorin
                          known as gorin002
                            We use a non-acid, non-phosphate, non-caustic wheel cleaner that is absolutely fantasic.
                            Email me buda@detailplus.com and I will steer you on to the manufactuer.
                            REgards
                            Bud Abraham
