Hey fellow pros,
I've recently begun charging for my work and enjoying it a lot. My niche is in detailing MINI Coopers--I've buffed out over 140 of them this past year, and I use my own MINI as my detailing rig. Of course I detail other cars too--thus far, mostly Mercedes and Audis, but have done the Fords and Saturns too.
Since space is at a premium, and eventually I will be towing a small trailer when I need to bring water, right now I'm trying to be fully self contained and I get a kick at watching the customer be amazed at how much stuff fits in the MINI.
The only thing I'm really missing now is portable power, and I'm considering either a heavy duty power inverter which I've seen for just over $100 and maybe running it off a couple of external car batteries or buying one of these:
Does anyone know if a 2000 Watt generator like the Honda EU2000i would be sufficient to run a rotary buffer and PC?
It interests me because it weighs about 50 pounds, runs economically, and is very quiet--I hear something around the level of an aquarium pump.
Also you can connect two of these together to produce 4000 watts if necessary. While I know there are cheaper generators out there, there aren't any this compact or practical.
Another option which is more compact at under 30 pounds is the 1000 watt model--again not sure if that's powerful enough. I'd like to be able to run 2 rotaries or 2 PC's simultaneously.
FWIW, I pack a 10x10 EZ up, complete detailing kit, M80, M83, M21, M7, Full NXT line including NXT Tech Wax--Makita rotary buffer, 2 PC's, 3 portable chairs, portable table, MF towels for paint, for wheels, and interior, foam pads--w7006, w8006, w9006, air pump, 2 vacuum cleaners, 2-5 gallon buckets and associated towel, mitts, absorbers. Degreasers and chemicals and dressings. Leaf blower and attachments. 200' in extension cords.
Thanks for any advice or insight on generators!
Richard
Richard
