Tire Shine sling mistake.
  • #16
    Originally posted by ebpcivicsi
    Sounds like you have figured out the problem, but FWIW.... After I apply Hyper-dressing to my tires, I let it set up, then use a blower to dry the dressing. It blows any build up out of the ribbed sections of the tires and prevents sling.
    I might give that a try. I usually use the leaf blower to dry after washing anyway. Good Tip. Thank You
    Jeff Smith
    • #17
      BTW, Mike or Tim
      If you guys see this I think the code Snippet for the NXT Tire Cleaner must need fixing. It does not display a pic.
      Jeff Smith
      • #18
        Originally posted by Jeff Smith
        BTW, Mike or Tim
        I just fixed it in here by correcting to :
        One of you guys might want to edit the Code Snippets link. I just found Chris's link for reporting errors, I'll submit to him.
        Jeff Smith
        • #19
          When you apply Hyper Dressing onto the tyres, do you guys face the problem of HD dripping all over the place? Each time I spray HD on the tyres, it will drip all over the rims
          • #20
            I don;t spray directly onto the tires. I spray onto an Eagle One Tire Swipe then Apply. I get no immediate Dripping but do get some sling if I don;t do a good job of pulling off the residue from around the raised lettering.
            Once I apply it I wait a while then Go back over the same tire without reapplying product to applicator. This helps drink up the residue a little. Something else I just started doing is this> I live 1 mile down a side road. I can drive this mile, which has a spped limit set at 30 MPH. I then pulled over at a little parking lot, pulled the tire swipe out and caught the sling before it had a chance to sling off the tire. I then drove about 10 miles to work with no sling issue.
            I think the majority of the tire shne products has the possibility of dripping and sling. Each seems to have it's own characteristics and can take an application or 2 before getting the hang of it. This seems to be my case anyway.
            Jeff Smith
            • #21
              BTW, Mike or Tim
              Thanks Jeff! It will be looked into.
