nxt wax and nxt spray wax?
  • nxt wax and nxt spray wax?
    if i were to nxt wax my car today, wash it every 2 weeks (no qd in between) and use nxt spray wax after every wash, could i possibly hold off on doing a full nxt wax for 2-3 months?
    the car in mainly parked indoors at night, but its outside for most of the day while im at work.
    Re: NXT wax and NXT spray wax?
    Originally posted by fgraciano1980
    if i were to NXT wax my car today, wash it every 2 weeks (no QD in between) and use NXT spray wax after every wash, could i possibly hold off on doing a full NXT wax for 2-3 months?
    the car in mainly parked indoors at night, but its outside for most of the day while I'm at work.
    If you NXT Spray Wax after each wash you could hold off easily for 2-3 months.
    It's all about doing something often to the paint.
    The most important thing is to get the technique for applying and removing a spray wax. Read both of these and find a method of applying the spray wax that you like best. Applying the spray wax is the tricky part. You want a thin coating and you want to use something to apply the wax, spraying directly onto the finish works, but applying it with something works best. Also, be sure to shake the bottle before using.
    Here are two threads that discuss how to apply and remove Meguiar's spray waxes...
    Using Meguiar's Even Coat Applicator to apply NXT Spray Wax
    How To Get Great Results With Meguiar's Spray Wax!
      Re: Re: NXT wax and NXT spray wax?
      thanks mike. i need to find a good way to apply this stuff. this sunday i had a really hard time removing it as i probably put on to heavy of a coat. i used a foam applicator pad to apply it and mf's to remove it but it was tough. i found myself having to dampen the mf towel a bit with qd to help remove some of the excess. ill read up on those links you provided...i was ready to bust out the g100 to aid in the removal
        The easiest way to apply a thin coat is with one of these,
        or
        Ultimate Wipe
        Normal/Small size microfibers work pretty well, dampen one side and continue to use that side. Large microfiber like our Supreme Shine Microfiber are too large for this and waste too much product as they absorb too much in and try to remove it as you're applying it.
