Really need some expert advice on this….
  • Really need some expert advice on this….
    I have a 2016 Audi Q5 in blue metallic that I just bought a month ago. Very clean vehicle that I enjoy so far. The hood came with a bunch of scratches from maybe a cat or bird or something. I decided to take this to a body man I have known for 15 years to wet sand out as I was unable to get them out with UC and Fine Cut Cleaner. I tried several times by hand with no luck.
    When I picked up the car it looked amazing but the next day in the garage I noticed all his wet sanding marks were showing. So I took it back to him to polish again. He was using a rotary with foam pad and 3M step one compound. He said he was having a really hard time getting his 2000 grit sanding marks out and mentioned how hard the paint was (repaint maybe). He asked if car had a coating on it or something. I don’t know this answer. He polished again and the next day I noticed the spots are coming back again. Also, in the sun I noticed terrible, terrible holograms on the hood and front fenders now. Awful. Actually this is the worst part.
    Next day I took to a detail shop to show them everything. They said they can wet sand again and polish out with a DA and make it look great. I also asked about PPF for the hood only and they can do this as well. $150 Canadian for the clean up and paint correction and $500 for the PPF.
    Now my concerns are that a lot of clear has come off with the original wet sand and polishing 5 times basically. Now to correct the shop will lightly wet sand again and polish to remove the holograms with a heavy cut compound, etc. I worry about burning through the clear or reducing it to being very weak which is why I may wrap it in PPF to provide more UV protection, etc.
    Now I don’t know what to do because I cannot leave it like this. I should have left it alone. I paid the body man $280 to essentially make the hood a lot worse. Now I have to pay another $150 to try and fix and then possibly $500 to PPF it. I could have just repainted it for what I may end up spending.
    What should I do here? Continue to have it fixed and leave it? It’s a daily and hits the highway a lot.
    Fix it and wrap with PPF?
    Just cut loses and paint the hood now? I’m not sure what that would even cost. I’m pretty pissed off now and this is the wife’s car and she’s not happy either after asking me to leave it alone.
    Depths:
    Walking down the drivers side I get readings of 142 to 252. Passenger side of 139 to 165.
    Hood I get numbers from 140 to 187 to 200 in one area. One heavily sanded and polished area I get a 128.
    Thanks for all help.
    Well look at it this way, if the hood's looks bug you now, it will always bother you. So everytime you look see it you will grit your teeth. So basically the hood is screwed for you. So if you take it to this new detailer and they do fix it, you will be happy. If they screw it up, your in the same boat. But, at the very least they will fix it so it looks better than now. If it's at a point where only a repaint will fix it, well maybe the repair will be good enough right now. ***** the bodyman didn't do it right. Been there before when mechanic didn't fix issues but I spent $$$.
      I agree with Buddy I think you have partly answered your own question "I cannot leave it like this". Whether you have it corrected & PPF'd or repainted is a tough call. I would probably go for the correction first and inspect before you have it PPF'd. If they do a good job, you can decide from there.
      Nick Winn
      Irvine, CA
      nawinn@meguiars.com
        Thank you for the response. That’s sort of where I am leaning to. See what they can do they decide how much further I’d like to go. I’d probably repaint at this point but wife is mad I even messed with it.
          I’ve seen this a lot—where the first fix makes the situation worse, and then it snowballs. At this point, I wouldn’t risk another full wet sand. Your instinct about protecting what's left is spot on. A light finishing polish and then wrapping the hood in PPF would give you a solid layer of protection from UV and road debris—especially if this car sees a lot of highway time.
            Originally posted by Brenan Jiran View Post
            To protect a paint scrape from rust, the key is to seal it quickly and thoroughly to prevent moisture from getting under the paint. Start by cleaning the area carefully to remove any dirt or debris, then use a touch-up paint designed for your car’s color to fill in the scraped area. After that, applying a clear coat can help seal the area. For longer-lasting protection, consider applying a ceramic coating over the repair once it's dry.
            This post was not about a paint scrape. Are you a bot?
