DA power system
  • DA power system
    Hi
    I just purchased a DA power system with the cut, polish and wax pads. When I try searching results come up with the full on DA tools. Is there a different process or technique to using mine? Was wanting to read up on the correct way to use ultimate compound, polish and wax with this tool before I start.
    09 Ford Explorer Limited AWD
    I have the DA power system. It works really well. When I use ult compound, I just do a 2 ft x 2ft area. then wipe it off right away. Don't let it dry. Same with ult polish. I apply ULW by hand. Mostly I use the DA power system with 3 in 1 wax and the yellow polishing pads. The process and or technique is the same as a regular DA polisher. If you're a hobbyist and not a fulltime detailer, this is a sweet little tool to use. Hope this helps. Franco
      I'm just a hobbyist so bought this tool to cut down the time it takes to do my own SUV. I also clean my parents so will help. Thanks for the tips
        Hi we have an older but still valuable video on this system. Also many of the same techniques in the below article also apply to our DA Power System.
        D/A Polisher Basics with Meguiar's MT300
        Nick Winn
        Irvine, CA
        nawinn@meguiars.com
