buckets for washing
  • #31
    Originally posted by amg/md
    Jeff,
    Did you have any problem installing the casters? I had to use pliers to squeeze a couple of the brass rings back into place so I could slide them into the openings on the bucket bottoms
    Then it slid back out when I rolled them over an uneven area to the street to empty and rinse..
    Yes, 2 of them needed the same tweaking with needle nosed pliers. The next time they fall out just put something behind the brass rings and pry them out just a tad. It sounds like you compressed them too much.
    But other than that they are great. The screw on lids work like a charm; give 'em a twist and they close all the way by themselves just about.
    I like what you said about storing stuff in them to keep them clean and handy.
    I also got the padded seat cushion. But I do not have a 3.5 gal. bucket. Would that be a good size to put the pad on for sitting and rolling when using the DA on lower body areas?
    Re: the 3.5 gallon bucket. Yes it is great for that. That was the main reason I wanted it. I am going to get one more dolly so I don't have to keep separating my 2 bucket setup. If I keep doing that I am likely going to end up losing one of the little brass clips.
    Jeff Smith
    • #32
      Jeff,
      Thanks for the advice on the brass rings. Sounds like a good idea.
      I'll probably order one 3.5 system soon because I get my DA and supplies on Friday.
      2006 Mercedes C-55 AMG black
      2000 BMW 328ci silver-totalled by son (no injuries)
      1998 Dodge Dakota Sport 4x4 deep amythest
