I picked up one of each of these.
Just thought I would share that I was impressed with how well things came out.
I used the Eagle1 Tire Wipe. They are about $1 to $2 each and work very well with.
I sprayed the tires with water, then I sprayed them with the Nxt Tire cleaner. Waited a few seconds then scrubbed like a mad man with the Eagle1 Foam Brush.
Finally I rinsed them clean.
Did all the wheels then went around and dried them.
Next, I sprayed them with Insane Shine. They are cleaner than new. Just the Tire Cleaner itself makes them look near new.
I was impressed. The Nxt Insane Shine left a stain in my driveway though. I sprayed that with the Hot Rims All Wheel Cleaner and the Insane shine rinsed off my driveway.
I just thought I would let everyone know if they want to be shocked and amazed they should buy both a can fo the Nxt Tire Cleaner and Insane Shine.
Get both of them and you will get brilliant results. Also get the Hot Rims All Wheel Cleaner because it is strong and safe. With those three things you should be able to really do wheels and tires well.
Oh, you will need a tire and wheel brush to to do everything right. You can be like me though an use the $1 or $2 Eagle1 Tire Swipe Foam, and then a toohbursh for cleaning the wheels. I actually had an old Crest Battery brush. Need I say more than it works wonders on wheels with hot rims cleaner.
