Best Wax for thinner paint jobs
  • Best Wax for thinner paint jobs
    I was just wondering what i should be using for wax if my paint is thin and has no clear coat. Basically what im trying to say is which kind of wax will give me that great shine but pull up the least amount of paint. Thanks for your time.
    Re: Best Wax for thinner paint jobs
    Originally posted by throughmyshadow7
    I was just wondering what i should be using for wax if my paint is thin and has no clear coat. Basically what I'm trying to say is which kind of wax will give me that great shine but pull up the least amount of paint. Thanks for your time.
    If the paint is in excellent condition then you can use a pure wax with no cleaning ability like Deep Crystal Carnauba Wax or M26 Hi Tech Yellow Wax.
    When you run your clean hand over the finish is it smooth like new glass?
      Re: Re: Best Wax for thinner paint jobs
      Yes, it is very smooth. Im not sure if it is "thin" but im pretty paranoid becuase its a 78 among other reasons. Thanks for the help.
        A couple of things,
        1. I have a lot of experience restoring original, older single stage paints and I completely understand the mindset of doing everything possible to try to preserve original paint.
        2. Even if the paint is in great shape and has been well-taken care of over time, it's possible that at some level there is DIP dirt in paint, and also oxidation. Neither of which these two things you want in and on your paint.
        If it were mine, I would tend to want to rub the finish down with some Deep Crystal Paint Cleaner and then polish with a pure polish and then use a pure wax.
        None of the above products are very aggressive at all and the Deep Crystal Paint Cleaner is chemical only and as long as you use a gentle and soft touch it should be completely safe on this older finish.
        You could always try it in a little section and check your results.
          A couple of things,
          Wow, thanks! This is exactly what i needed to hear. Now I have a plan. Thank you so much!
            No problem.
            Visit a couple of auto part stores or retail stores like K-Mart, Target, or Wall-Mart and find a couple packages of these, High-Tech Applicator Pad and apply every product using them as foam is more gentle to the finish than a fiber type applicator and you're looking to be as gentle as you can.
            Any chance you have a digital camera and take a few before and after photos?
            Also, if you send me your phone number I'll call you and give you a few other tips...
            mphillips@meguiars.com
