Quick Detailer vs Speed Detailer?
  • Quick Detailer vs Speed Detailer?
    Which should I use.
    Both are said to be good for removing bird droppings...
    Will they both yield the same results when used with the Microfiber?
    Also, can they both be used with the claying process?
    Thank You much.
    The Quick Clay will come with a bottle of QD. Once you cut up the clay into 3 or 4 peices, you will probably run out of QD before the clay.
    Both work with the clay.
    As far as removing droppings, etc, since ou use Nxt wax, I would probably use the Speed Detailer, since they are in the same family, though everyting is compatible with each other.
      Thank you.
      I am buying Quck Clay and extra Quck Detailer for use with the clay. In addition, I am going to buy Speed Detailer and keep it in my car with a supreme shene microfiber.
      Thanks much.
