Hot Shine Spinoff Problem
  • Hot Shine Spinoff Problem
    After I sprayed the Hot Shine on my tires I let it dry for 5 hours before I drove around. After driving there was spray all over the paint, glass and plastic panel under the door. How can I avoid this spinoff problem?
    thanks.
    The easiest way of avoiding sling is to wipe the tires down with a towel after you have first allowed to the product to dry. By removing the excess product you will limit the potential for slinging.
      Re: Hot Shine Spinoff Problem
      thanks.
      i've had this problem with virtually every aerosol spray as well (except armor all tire foam). after i have had sprayed the tire... i let it sit for about 15-20 minutes, then take a tire swipe and spread it around evenly. it's worked pretty well, and i've had very minimal slinging if not any at all...
