Quick question on Claying.
  • Quick question on Claying.
    I Bought some megs Products today one including the Quik Clay System. They Clay is a Good Size brick Do I use all of this, or do I make this 1 bar into 2 er 3 bars? And how should the bars I dont use be store'd? And how dirty should the bar be before I Fold it over?
    Support The Troops, Americans, Canadians, British. If They Are Ours Support them.
    Re: Quick question on Claying.
    Welcome to the forum AJSP.
    Cut the bar into and store the pieces in a plastic freezer bag, or a small Rubbermaid like container.
    When you get ready to clay you vehicle, use 1 piece of clay and make a patty out of it (about the size of your palm). Spray the QD on the patty and the area to be clayed and then start rubbing that area, but be sure to use a lot of lube or the clay will stick.......Keep a good clean towel handy to wipe off the QD before moving on to another area.
    After the clay starts to turn dirty looking, then either turn the clay over or knead it into a new patty, as this will expose fresh clay to work with.
    Here's a thread that has some pictures of a dirty clay bar.......Just scroll down a little ways to see it.
    1986 Ford Bronco II - Extreme Makeover (http://meguiarsonline.com/forums/showthread.php?t=88) As luck would have it, I was in need of a good before and after vehicle to demonstrate Meguiar
    r. b.
