scratched headlight lens
  • scratched headlight lens
    just noticed that the sheet of plywood that sailed in front of my car also scratched the headlight lens. About the size of quarter, when I run my fingernail across I can tell the plastic is scraped/scratched pretty good.
    Are there any recommendations on how to remove that scratch? I have a DA and rotary at my disposal.
    thanks
    Armand
    '02 Lex. GS 300/silver
    Here's an article I wrote on this general subject...
    In order to remove a scratch out of anything, metal, plastic glass, paint, etc. You must remove material around the scratch until the surface is level or equal to the lowest depths of the scratch or scratches.
    The below diagram if for paint, the the same thing applies to just about an surface material or coating.
    In essences, you don't really remove a scratch, you remove material around a scratch.
    Then the big question is, is the material or coating workable, as in can you abrade small particles of it and leave behind an original looking surface. For example, some things you can abrade, (remove the scratch), but you can never completely remove all of your abrading marks, thus you can't really fix the problem, all you can do is exchange one set of scratches of a different set of scratches.
    The next questions is, how thick is the surface material you're working on or the coating. You are limited to what you can do by the thickness of these to things, (surface coating or surface material), and whether or not this surface is workable.
    Sometimes you don't know what you can so until you try. It's always a good idea to test your choice of products, applicator materials and application process, (By hand or by machine), to an inconspicuous area. If you cannot make a small area look good with your product, applicator and process, you will not be able to make the entire surface look good. It's always a good idea to test first and error on the side of caution, versus make a mistake you cannot undo.
    End of article
    To remove a scratch out of your headlight lens completely may require you to sand it out and then buff out your sanding marks. In situations like this, each person has to decide if the time, work, energy and expense is worth it, or if you might just be better off replacing the lens. If the lens is Lexan, you likely won't be able to remove your sanding marks as Lexan does not lend itself well to polishing.
    A lot of times you are well off to merely improve the look of a scratch using a product like PlastX than to try to completely remove the scratch.
    PlastX
