Just curious how often it's recommended to do the Meguiar's 3 step wax products? Or is there a way to tell when the vehicle needs to be done again? Any help will be appreciated. Thanks ahead of time.
How often do you use the 3 step..
Well, the squeak test can be used to determine when your wax is wearing off. At that point, you would determine if you paint needs cleaned/polished as well.
I use the spray booster wax after washing as much as possible, to extend the life of my wax job, and when the spray wax becaomes harder to remove, is a good sign of when to re-wax.
The actual amount of time you have is hard to say, depending on garage kept or not, daily driver, weather conditions, etc. They could be used every day with no ill - effects, other than a sore arm and no life...2017 Subaru WRX Premium - WR Blue
Re: How often do you use the 3 step..
Proper car washing is going to be your key for the best looking finish in the long run.r. b.
