Any difference in method of priming a new/clean pad when using with rotary and PC?
Priming New/Clean Pad
Tags: None
Re: Priming New/Clean Pad
If you like, you can prime, (wet), a new pad, or a dry clean used pad with a little quick detailer before applying compounds, paint cleaners or even cleaner/polishes.
Any quick detailer will work. I don't do this myself, but I know others that do, especially with the W-7006 and W-7000 foam cutting pads when they are new/dry as they are pretty aggressive as far as foam goes and wetting them adds a little softness/lubricity to the pad/surface when you are first starting to buff.
After your pad begins to become saturated with the product you're applying this no longer is necessary.
Re: Re: Priming New/Clean Pad
Originally posted by 2hotford
Some like to place an "X" on the pad of product but this can sometimes cause sling on the initial start of the buffer.
It only takes a few seconds with the trigger pulled on the rotary buffer to remind me why not to do this!
Thanks alot Tim & Mike. I got the answers clearly. I was thinking usually the inner area of the pad is holding more product compared to the outer area of it. So whenever the outer area touches the surface, it might swirl up if we do not prime the pad to add more lubricity and softness.
After you've been buffing for a few panels your pad should be pretty broke in and as long as you make a few cover passes over the area you started out on, you should remove any potential swirls that may have been instilled.
If you're starting out with a foam cutting pad, a second pass using a foam polishing pad and a less aggressive product will also remove any start-out swirls from not priming the pad also.
I've read somewhere in this forum about laying a strip of 6"-8" of product and to be picked up by rotary at 10 o'clock for 2'X2' of area. As a beginner, I'm always working with 1'X1' of area, can I just lay 3"-4" strip of product?
Re: Re: Re: Priming New/Clean Pad
Once in a while I do this by accident as a result of showing people often how to apply product to a foam pad when using the dual action polisher.
Rangerpowersports.com
Ranger72
