Can you ???
  • Can you ???
    Can you take the wax off with the g-100a?? Or do you just put it on there with the buffer?? I have always used a orbital buffers in the past, I put the NXT on, and off with a orbital..
    Sure you can. Simply place the bonnet over a clean, dry foam pad,
    Then place the variable speed setting on the 5.0 setting and push down with about 4-5 lbs of pressure and remove the wax.
      The G100 with the bonnet does a great job of removing wax.
      I feel gives you a slightly better look over a hand removed wax and its very quick.
      Brandon
      2007 Black Chevy Avalanche
      My Albums: Avalanche
        I wonder if the microfiber bonnet can be used to remove polish?
        r. b.
