Ok, here it goes, I have a 1998 Mustang GT, that needs "Jesus"!!! The car looks like someone washed it with a brillo pad, it is BAD!! So, I just bought a Meguiars dual action polisher with 2 pads, but, I don't know what all I need to get it pretty again. I allso have a 2002 Mustang GT, I have used all Meguiars products on that one. I need to know what PADS, POLISH, CLEANERS, COMPOUNDS, basically everything. PLEASE HELP !!!!!! Here is a pic of the 2002 GT
Need a little help ( PLEASE )
Hi x02gt,
Seeing this is your first post... Welcome to Meguiar's Online!
Ask and you shall receive...
Tips & Techniques for using the G-100a to remove swirls and other paint defects.
Products Used
Quik Clay System
G-100a
W-8006 foam polishing pad
W-9006 foam finishing pad
#83 Dual Action Cleaner Polish
#80 Speed Glaze
Meguiar's NXT Generation Tech Wax
Ultimate Wipe
Ultimate Bonnet
First wash the car thoroughly. Pay special attention to loosening and removing any dirt particles from cracks and crevices to prevent these dirt particles from being introduced onto the surface during the polishing process. After washing and drying, inspect the surface both visually for below surface defects and with the palm of your clean hand for above surface defects.
If you feel any tiny little bumps still attached to the finish after washing, proceed to clay the paint to safely remove these contaminants. After claying each panel, wipe the panel down with a quick detailer to remove any residue.
Using Painters Tape, tape-off any plastic trim or components that you don not want to get product onto and also tape-off any edges, high points or areas with known thin paint.
Your car may not look like the below car, but the taped-off areas should...
Applying #83 Dual Action Cleaner/Polish with the G-100- Speed Setting - 5.0
- Arm Speed - Slow Arm Speed
- Pressure - 4 to 5 pounds of pressure on the head of the polisher
- Work Area - Work a small area at a time, about 1 foot square
- Overlapping motions - Overlap each pass by 50%, move the polisher using different patterns
- Time - Work the product until the diminishing abrasives have broken down, but you haven't gone completely to a dry buff.
- Amount of product - Don't overuse product, use enough to lay down a film in the area you are working
When using the G100 Dual Action Polisher to remove defects, (This is different then merely applying a polish or a wax because you're trying to remove paint), you need to use a slow arm speed and overlap you passes by 50%. You also want to go in at least two different directions, for example, from where you're standing, side to side, then front to back. You can also move the polisher in a kitty/corner fashion for complete, thorough and uniform cleaning action.
Only work a small area at a time, this will vary according to the shape, curve or body line of the panel you are polishing but for example on a large flat panel, you want to stay around a 12" to 18" squared area. The point being, don't try to work to large of an area all at once or you won't remove the defects equally everywhere.
When you move on to a new section, overlap into the old section for a uniform end results.
When it comes time for applying a pure polish, or a wax, (besides cleaner/waxes like ColorX if you're doing a one-step), the you can polish larger areas and spend less time, i.e. use less passes.
The point of the cleaning step is to remove the defects. Because the G100's polishing action is gentle and therefore safe, it takes time to remove small particles of paint in an effort to remove a defect.
If the below image represents swirls and scratches evenly distributed throughout your car's finish,
Then you can see that in order to remove the defects you need to remove the highest areas of the surface until they are level with the lowest depths of the deepest scratches. In essence, you must remove paint.
Applying #80 Speed Glaze with the G-100- Speed Setting - 4.0 to 5.0
- Arm Speed - Medium Arm Speed
- Pressure - 3-5 pounds of pressure
- Work Area - You can work a larger area than what you do with the #83 DACP
- Amount of product - Don't overuse product, use enough to lay down a film in the area you are working. Speed Glaze is rich in polishing oils a little bit goes a long ways
Applying NXT Tech Wax with the G-100- Speed Setting - 3.0 to 4.0
- Pressure - Light pressure - More than the weight of the machine, you want to engage the foam pad with the surface, not just float over it
- Work Area - You can work panel by panel, for example, apply to one half of the hood, then walk to the other side of the car and apply to the other half of the hood. Apply to fender all at once, door, deck lid, etc.
- Time - Work the product long enough to make two passes over the finish then move on
Removing Polish or Wax with an Ultimate Bonnet on the G-100- Speed Setting - 4.0 to 5.0
- Time - Work the area until the bonnet has removed the wax
Thank you very much! I have always been a freak about my car, I will wash it in the rain, yeah a freak, but my 02 GT looks great, I use the NXT products on it, and I do alot of other cars on the street, but this 98 GT need more HELP than I have ever given a car before, so just needed a little help from the professional!!!!!
