The product seems similar to IronX which is very popular in the market. Is it safe to use Ultimate All Wheel Cleaner on paint if I'm going to follow up with rinsing, claying, polishing, and applying sealant?
Can I use Meguiars Ultimate All Wheel Cleaner on paint as Iron Decon before claying?
Re: Can I use Meguiars Ultimate All Wheel Cleaner on paint as Iron Decon before clayi
Take a look at this announcement thread of recent different product for Meguiar's Iron Decon.
Meguiar's D1801 Professional Wheel & Paint IRON DECON
Meguiar's D1801 Professional Wheel & Paint IRON DECON (https://meguiarsonline.com/forums/showthread.php?67026-Meguiar-s-D1801-Professional-Wheel-amp-Paint-IRON-DECON&p=587806) This pro-strength unique gel formula will safely & effectively remove embedded iron particles from body panels, wheels and painted brake
Originally posted by Old Bear View PostTake a look at this announcement thread of recent different product for Meguiar's Iron Decon.
Thanks, I saw that one but I only decontaminate around once or twice per year my personal car so not really worth it to buy a gallon
Originally posted by Old Bear View PostDid you notice the small discussion comparing the two products starting with post #29 through about #35?
You can safely use it on paint but it's certainly not ideal being a thicker gel, as you mentioned. If you are looking for a smaller size decon product you might consider our Detailer RTU Iron Removing Spray Clay, which is derived from D1801 Wheel & Paint Iron Decon:
https://meguiarsonline.com/forums/showthread.php?69243-Meguiar-s-Detailer-RTU-Iron-Removing-Spray-quot-Clay-quotNick Winn
Irvine, CA
nawinn@meguiars.com
Originally posted by Nick Winn View PostYou can safely use it on paint but it's certainly not ideal being a thicker gel, as you mentioned. If you are looking for a smaller size decon product you might consider our Detailer RTU Iron Removing Spray Clay, which is derived from D1801 Wheel & Paint Iron Decon:
D1801 seems like a great option though, thanks! I'll try to find this.
Edit: on the D1801 thread you replied:
"So is this basically D1801 with some slickness to make it a clay lubricant?
Yes exactly, but not as potent strength as D1801 Wheel & Paint IRON DECON. This is also not designed for wheels."
Originally posted by vwite View PostThanks Nick, yeah I'd imagine that would be the major "con" on paint, even for a wheel it takes like 20 sprays to properly coat it so I'd imagine for the whole surface of painted panels would be the whole bottle. If I do use UWC, it would be best to apply, wait, rinse and then use a clay bar with specific clay lube or can UWC be also used as clay lube as long as I rinse after working each panel?
In case I cannot find D1801, could I combine UWC with a slick clay lube (or spray them both from separate bottles), then use a clay bar or synthetic clay pad/towel?Nick Winn
Irvine, CA
nawinn@meguiars.com
