I can definitely relate to your situation.
The El Camino was painted in 2013, and I purchased it in early 2014.
I have never taken a water hose to anything but the aluminum wheels.
I found I had to abandon the car duster. In fairness, it was not a California Car Duster brand.
Primarily, I use Meguiar's Ultimate Waterless Wash and Wax (G3626) or Meguiar's Rinse Free Express Wash and Wax (D115 diluted 4:1).
D115 comes in a gallon and is a concentrate. It is designed to reduce costs by diluting with distilled water. Then using a quality mist sprayer on the smaller bottle.
Be cognizant of storing detailing supplies in those cold windy OK winters. Been there, and did not have a garage. I know those ice storms can be cold and summers hot.
One thing that might help is being OCD on towel management.
I don't want to rub dirt or dust into the paint.
I start by folding the quality microfiber towel in half and then half again.
That makes 8 sections of the towel.
I then spray a panel or maybe only 1/2 of the rear fenders, top or hood.
Now, I visually break that down even further.
I take a small clean sub section of the 1/8 towel section, like the very end and roll the edge as I make one swipe.
My goal is to pick up the dirt, yet rather than a hard 3/8" dark line, I want to see the dirt picked over a wider 3/4" to full one inch section.
This technique tries to not push the dirt into the paint, by providing clean towel as you roll it with you fingers.
The towel section is then curled and a new section is provided as we do the next wipe.
Don't allow the dirt from the towel to touch the clean parts of the towel or the paint (reduce as much as possible).
Remain aware of where the dirt is on your towel.
Check frequently for wide rather than narrow lines.
I might only get 4 or 5 wipes from a towel section.
Use a separate microfiber towel to lightly buff after each 1/2 section or full panel.
Rotate the buffing towel folded into 1/8th through to clean sections as needed.
Does it matter if you use 6 microfiber towels or 16 microfiber towels to clean your car?
You are going to wash them anyway in a separate wash load.
Hopefully this image will illustrate what to expect to see on your cleaning towel.
