Last time I was on this forum I started a thread asking for help on dealing with water spots and swirls... now the real deal is here for me, I received a fresh rock chip, first one since I bought it new.
I've done my homework by watching some youtube videos, I got a basic understanding of how the process works. However I have some doubts on how to proceed with the situation:
1. The exposed plastic is rough, the edges are prominent, should I smooth it down using wet sandpaper, claybar, or compound?
2. The rock took the paint off completely and then scuffed the upper spot as well, as can be seen in the photo. I want to use touch up on the bare plastic spot only and not expand the touch up paint to a bigger area than necessary, though I'm unsure which will look better in the end. What would be the best practice here?
3. The touch up pen I got at the dealer has one tip instead of duel tip, will this provide a finish that blends well with other areas? Don't they usually use a base paint then follow up with a clear paint? Although I know it's possible to blend clear with base together, I don't know if it's the case with this pen. Does anyone here have experience using it?
This is the first time I'm faced with a rock chip, so I really could use some advice. Thank you!!
