Quick Detailer M66
  • Quick Detailer M66
    Is M66 will remove pervious rotary hologram or I should go first with M205 first.
    Re: Quick Detailer M66
    It depends on how severe the rotary holograms are and also which machine you are applying the M66 Quick Detailer with. Typically holograms inflicted from a foam pad on a rotary are more difficult to remove than ones inflicted from a wool pad.
    Nick Winn
    Irvine, CA
    nawinn@meguiars.com
      I'm planing to use Flex rotary with finishing or polishing pad with M66. Is that sounds good or you prefer other approach.
        A rotary & M66 applied with a foam polishing or finishing pad should have the ability to remove very light previously inflicted holograms, again just depends on the severity of the holograms. If you are looking for a one step approach, our D151 Paint Reconditioning Cream will provide more cut & defect removal especially when used on a rotary.
        Nick Winn
        Irvine, CA
        nawinn@meguiars.com
          M66 with a PC is a great jeweling product.
          Tuck91 uses/used it a lot with awesome results. As well as I.....
            Thanks- I used M66 with DA/finishing pad last weekend and I like the result on black car.
