Any thoughts with this procedure..UWWA followed by PP 365 then UQW....Thoughts Ideas..outside water is off.
Ultimate Wash & Wax Anywhere..
Re: Ultimate Wash & Wax Anywhere..
If this is what you currently have on hand then go ahead and proceed on.
If water access is an issue, i'd use a 5 gallon bucket/ gamma lid with D114 then PP365/ UQW.
This is the time of year I don't feel comfortable using UWWA"STRIFE" aka Phil
since all products are within the Meguiars line, you should be fine. UWWA does leave behind a wax layer of protection so PP365 will not "bond" as well as it should if you had used D114 (Rinse Free Wash) and then added PP365/UQW. So I would agree with STRIFE of using D114 then PP365/UQW
I personally like using 3 gallons of water in a 5 gallon bucket with a gamma lid with pre-soaked towels waiting to be used. It makes clean ups quick and easy as well as reducing the washing process/time when I wash the car. I have white wheels so I still have to break out another bucket/foam cannon to clean the wheels but that is another issue entirely. I also have a spray bottle on hand of D114 in a 8:1 dilution ratio to pre-soak the panels prior to using the rinse free washing method of D114 at 256:1 dilution ratio. Ironically, I also find cleaning/washing the MF towels after they are used is easier since they are pre-soaked with wash solution vs the traditional 2 bucket wash method followed with LSP/drying
I would not worry about it too much as the solvents within PP365 will remove most of what UWWA leaves behind.
Originally posted by 02Rodeo View PostWhat about going thru a touch free car wash and then following up with PP365 then UQW....A basic wash with no wax or polish..
It's the soap that is bad in the touch free car washes; it will degrade, or remove, the wax on your paint. I wish you could do just a spray off and then spot free rinse with no soap. If you're going to wax with PP365 afterwards each time, knock your socks off I guess.
Originally posted by roushstage2 View PostIf you're going to wax with PP365 afterwards each time, knock your socks off I guess.
Originally posted by 02Rodeo View PostAny thoughts with this procedure..UWWA followed by PP 365 then UQW....Thoughts Ideas..outside water is off.
Originally posted by twisty roads View Post... I also have a spray bottle on hand of D114 in a 8:1 dilution ratio to pre-soak the panels prior to using the rinse free washing method of D114 at 256:1 dilution ratio.
