Leveling touch up paint with Scratch X?
  • Leveling touch up paint with Scratch X?
    I have a door ding caused my some idiot who decided to swing their door wide open in a tight shopping center lot and it looks like it took some of the paint off with it. The total area of the missing paint area/ding is like half the diameter of a pencil eraser.
    Would it be a good idea to use touch up paint to repaint that small area?
    Can I use Scratch X on the touch up paint to level out that area with the rest of the paint afterwards?
    How should I handle that ding without messing up the surrounding area?
    I don't want it to turn out worse than it already is. Its the first ding on my new car
    Touch-up work like this is very difficult to do and make look good.
    As far as leveling the touch-up paint with ScratchX goes, probably not.
    First, don't put on a lot of touch-up paint to start with, that way you won't have any to remove.
    Second, sometimes when you start rubbing hard on touch-up paint you simply remove all of it.
    I feel your pain...
    After we purchased our Honda Pilot, the very first time we purchased a brand new car, shortly thereafter, we received a ding/scrap in the drivers rear fender, all the body shops want to repaint the entire half of the car to fix it the right way, the problem is, is I don't want to paint over all that perfectly good factory paint, so the ding/scrape is still there today.
    You might check with a couple of PDR companies and see what they can do with it.
      Mike,
      What's a PDR company?... Can you suggest the name of any?
      Thanks!
      #21 - Synthetic Sealant For Sale!
      Will ship internationally!
      Check the 'For Sale' section.
      Also selling #7 & Backing Plates
        The dinged area is located on the back passenger door (Honda Civic), located on a pretty flat area of the panel below the door handle.
        Would it be a wise idea right now for me to touch it up with touch up paint ASAP to protect it while I find the time to visit a PDR?
        The area where the paint got scraped off just looks white right now.
        Can I use Quik Detailer to clean off the spot first before applying the paint?
          If its metallic, then any blending or sanding you do will need to be done to a clear coat applied ontop of the metallic.
          If you sand metallic it becomes dull, and cant be buffed back.
          I have had success on home projects breaking off a little piece of 2000 grit, the size of the tip of my finger, and circleing the touched up area, very lighty.
            Hi Nyyanks81,
            I may be able to help you with your chip, send me an email with the color of your car and the location of the chip. I am in NJ - touch up is what I do... my company does reconditioning for car dealers. If you are close to Edison NJ or Morristown you could swing by one of my shops.
            Len House
            ProTouch Group Inc.
