how to remove Stain Trim
  • how to remove Stain Trim
    i need some help removing paint from the rubber trims.
    tried claying it didn't help. any help would be good.
    Well what i would first try if you have it. Klasse AIO. just spread over the trim and it should disppear. If you dont have that take a mr clean magic eraser, wet it, and VERY LIGHTLY rub against the trim. Dont go hard over the trim or it might cause discoloration. After the eraser apply a dressing for protection and to fee the trim.
    Greg
    Pinnacle Detailing
      wow... doesn't look good. Just a thought if you have some vinyl/rubber cleaner and a small brush might be worth a try.
      How did that happen?
      Brandon
      2007 Black Chevy Avalanche
      My Albums: Avalanche
        Yikes!!
        I would try the #39 as was suggested. If that does not work, try a light solvent like WD-40 and gently saturate the rubber and then remove the solvent and hopefully the paint splatter. You need to be careful as any aggressive rubbing on the rubber trim may cause permenant scratches in the rubber.
        Good luck and please keep us posted!
          i was thinking magic earser or tar remover. with a toothbrush or something. does paint thinner effect the trim or the car paint?. i probably won't be able to attack this till next weekend. looks like this weekend is rainning
            From what I understand the magic eraser is not for glossy surfaces so read the package if your rubber has some shine to it may dull it.
            from http://www.homemadesimple.com/mrclean/tips.shtml#eraser
            * The Mr. Clean Magic Eraser is a highly effective cleaning tool. Test first on an inconspicuous spot with light pressure to see if surface may scratch or dull. Not recommended for use on surfaces that are polished/glossy, or on brushed, satin, dark, or faux finishes. Do not use with chlorine bleach.
            Brandon
