I know I haven't posted here in a while but once I tried this product.....a review was needed. It is done rather hastily so excuse my lack of perfect pictures.
Imagine all of the trim was grayed out or dull on this vehicle. This product brought them back beautifully and acts as a coating which will last a looong time compared to traditional dressings.
Below:The license plate frame used to be gray and disgusting. But now it is nice and dark. The white spots are compound dust.
Below: The rubber seal around the sunroof used to be completely dull but is now nice and dark.
You can clearly see the over spray which is not too big of a problem. More on that later.
Below:The pillars between the doors. This is the first plastic protectant to actually stick to this surface. Although it runs a little, this simply shows me how resilient the protectant is.
Below: The trim below the windshield used to be gray and dull but is back to being dark and shiny. You can also see the over-spray on the windshield.
Below: The thin piece of trim running on the roof. It used to be gray and dull but is not dark and shiny. The texture isn't perfect but it is protected and feels like a coating. It feels very resilient.
The overspray is on the edges around the car and it was rough to get off the paint! I was compounding with the M300 with a Meguiars microfiber cutting pad and D300 Microfiber Compound. It finally came off relatively easy with this combination but if it was thick then I needed to get in there with a foam applicator by hand with very specific pressure.
However, overall this product is highly effective. It is truly remarkable how easily this restored the trim and how resilient it is.
I can see using this as step 2 or 3 in a complete detail. I could wash, clay, mask off all of the edges and spray the trim. This would eliminate the overspray and make compounding much easier as dust wipes off easier.
As a plus, this stuff will not just leave the trim if you touch it with the compound and pad. It is truly a coating and lasts on the trim.
The over-spray was my fault but not a big deal because the car is a daily driver and just needs to be protected.
I love this product!
