Washing Microfiber Rags
  • Washing Microfiber Rags
    Hope this not dumb question. Is it ok to wash the microfiber rags after removing wax or detail followups so to reuse microfiber rags. thanks all
    Re: Washing Microfiber Rags
    Yes indeed. Just make sure to wash them in their own dedicated cycle and not mix in any other towels or anything that isnt microfiber in that load. Do a quik search on how to wash your microfiber towels and you'll find lots of good info
      Related question: I have microfiber mit and microfiber drying towel. The instructions on both say "washing with similar microfibers" but doesn't really say what that means. Am I ok to wash those two together assuming no major dirt and zero oily stains on the mit? Only used them once. So far I've only rinsed the mit really well from the inside out and let it air dry after because I wasn't sure what to do with it / didn't want to ruin it after one use. Same with the towel.
      Also there's no instructions in terms of heat settings for driers and stuff like that. Just wash with mild detergent and air dry only for this stuff?
        Yes you can wash & dry them together. Wash a load of microfiber made towels, mitts etc. together in warm or hot [if extra dirty] water using liquid detergent, [free & clear preferred]
        Then you can dry using low heat. Do Not use dryer sheets/fabric softeners of any kind. No need to run them in the dryer for any longer than it takes to get them dry.
          Thanks much Eldorado! This is good news because I bought a separate mitt and towel for my wife's car too so we can wash them all together.
