paint care for a new car
  • paint care for a new car
    Recently had my new car taken in for some body work due to an accident...while i was picking it up the manager of the shop said i shouldn't wax my car
    the car is about 9 months old....I've been following the wash, clay, polish, wax routine every few months...about every 2 months for the polish and wax....and every about 5 for the claying
    the manager told me that i should only use a glaze.....any thoughts on this?
    Yes, that sounds right, even though the manager didnt explain himself fully it seems.
    What he should have said was freshly painted panels need to wait about 60-90 days to cure before waxing. In the meantime, it is safe to use a glaze or polish. Afterwards, you can wax as usual.
      thanks that makes sense
        Just to add to what Murr1525 wrote,
        It's safe to use a body shop safe polish or glaze. In the Meguiar's line, that would include,
        M03 Machine Glaze
        M05 New Car Glaze
        M07 Show Car Glaze
        M09 Swirl Free Polish
        M80 Speed Glaze
        M81 Hand Polish
        M07 is available in a 16 ounce container and is readily available.
        If you think you ever might want to do some machine polishing in the future, then the M80 Speed Glaze may be the way to go, just be aware that it is only available in a 32 ounce container. It does contain a special body shop safe, paintable polymer that provides a little bit of protection somewhat like a wax would, but will not hinder the curing process.
        Here's an article you might want to read...
        Paint needs to breathe
        Words mean things, just ask any Lawyer. Floating around on the Internet, and discussed for decades among car enthusiasts is the myth that paint needs to breathe.
        Or is it a myth?
        It depends on how literal you read into the words. If you apply the common definition used for the word breath, then “No�, paint does not need to breathe. If however you take a moment to understand the idea that is being expressed with this word, then I think you’ll understand why the word breathe is used when someone says, or posts to the Internet that �Paint needs to breathe�.
        The below is just my guestimation as to the story behind the theory or myth that paint needs to breathe. I may be wrong, but my years of working with both painters, detailers and serious car enthusiasts as well as teaching detailing classes makes me think that if I’m not dead on, I’m at least in the ball park. With that said, here my explanation of how the saying, “Paint needs to breathe� originated.
        For the last 50 or so years, when a person would have their car painted, upon retrieving it from the painter, the painter would typically recommend that the owner wait for a period of time before applying a coat of wax or some type of paint sealant that seals the paint. The normal period of time that most painters recommend is anywhere from 30 to 60 days and sometimes longer, depending upon the painter. The reason for this waiting period is to allow the different solvents and other additives enough time to fully evaporate out of and off of the surface.
        Wax and/or paint sealants, whether natural or synthetic, or a blend of both of these ingredients, seals the paint by coating over the surface and filling into any microscopic surface imperfections creating a barrier coating over the surface. This blocks, or inhibits these solvents from escaping through evaporation, or outgassing. Solvents also called thinners and reducers are used to thin the paint down so that it can be atomized into a spray when applied with a paint gun using compressed air.
        When a customer arrives at a body shop or a dealership to pick up their car with its freshly applied paint, most painters will tell the customer to wait a certain number of days before applying wax, or paint sealant over their new paint job. If the customer agrees, then that’s probably as far as the discussion goes.
        If the customer asks further questions as to why they must wait before applying a protective coating to their investment, then it is my belief that most painters would do their best to explain to the customer, in easy to understand terminology, so that the customer will understand and comply with his request. This is where I think the saying, paint needs to breathe, originated.
        I don’t think most painters would try to explain that the solvents need to outgas in order for the paint to fully dry and harden, instead, I think they would use a more simple approach and merely tell the customer that their new paint needs to breathe.
        The above fictional analogy is probably as accurate as any assumption as to how the theory that paint needs to breath was started. (I'm open to other theories however.)
        People that understand the painting process understand that paint doesn’t literally need to breathe; they do understand that fresh paint needs to outgas. This means that for a period of time, the solvents and other carrying agents, which are used to dilute paint to a thin viscosity so that it can be sprayed out of a pressurized air sprayer, need to work their way out of the paint through the evaporation process, also referred to as outgassing.
        Read the below two scenarios and then decide for yourself, which scenario sounds more plausible.
        In an effort to explain to their customers why paint manufactures recommend waiting for at least 30 days to pass before applying a coating of wax or a paint sealant, the painter can,
        • 1. Try to explain the outgassing process over and over again throughout their career.
          2. Use a simple analogy that the average person can understand without challenging the painter’s judgment or expertise.
        My personal guess is the second option.
        If the simple analogy works, it will accomplish the painter’s goal and allow the painter to get back to work, not spend his time explaining the painting process. The goal of course is to prevent the customer from sealing the paint with some type of wax or paint sealant until the paint has completely dried and the out-gassing process is completely over.
        • * Paint does not need to breathe in the literal sense that you and I need to breathe as living human beings.
          * Paint does need to breathe in the sense that fresh paint needs to outgas.
        Of course, in the last 50 years or so since World War II ended and the car crazy culture really revved up in America, (no pun intended), the result has been explosive growth in the collision repair and custom painting industries. It should be no surprise that the idea that paint needs to breathe has finally reached enough of a critical mass as to be the topic of discussion on numerous discussion forums as well as anywhere a couple of car enthusiasts gather to talk shop.
        Depending on how literal you want to read into it, when someone states �Paint needs to breathe�, what they probably mean is that fresh paint needs to outgas, they probably just don’t know, or understand the term outgas, and/or they are confused like many people who have gone before them and are operating under the wrong idea… innocently.
        A different, but related version of the above would be someone that applies the same idea that paint needs to breathe to the paint on a brand new car which is also false unless the new car has been painted within the last 30 to 90 days. Sometimes during shipping from the assembly plant to the dealership show room floor, new vehicles are damaged and need repair including repainting. If all the paint on the car is the factory original paint, then it was baked on at the factory as it traveled down the assembly line and was completely cured before it left the assembly plant and it is perfectly safe to apply a coating of waxy or a paint sealant. If the car has been repainted due to damage during transit, then the areas with fresh paint should not be sealed until the recommended waiting period has passed.
        Well, this is my stab at the “Paint needs to breathe theory�.
        Comments? Click here to post them to this article
          question...used final inspection on it today after a wash just to check out the finish of the paint job...is that bad heh?
            Using M34 on fresh paint is perfectly safe as M34 is formulated to be body shop safe.
              sweet thanks for the info guys
