Years ago, I had success (different car/paint) with #83 followed by #80 on the original G100 and the SoftBuff pads - back when the finishing pad wasn't black.
Anyway, here is the issue...
Car is a 2013 Infiniti G37 (Liquid Platinum - looks "silver" to me) and it is finally swirled.
Since I lent the G100 to a friend years ago and he liked it too much to return it
I bought a newer G110v2 probably about five (5) months ago and just got around to using it.
_______________
It has the Bigger W68DA backing plate, and I bought several of the Genuine SoftBuff 2.0 pads. I marked the backing plate with a Silver Sharpie, so I can see it rotating.
What I tried... Didn't work well enough:
What I did was use a black finishing pad, specifically W9207, on it and used some M205, which I presume for all intents and purposes is like the #80 I used to like in 2005/2006 on it is supposedly more user-friendly and is rumored to finish better than M82!
My Process that did not work well enough:
1. I wiped down the panel with a clean microfiber and plenty of detailing spray - specifically Final Inspection (simply because it was in a spray bottle nearby)
2. I clayed that panel with the same stuff... and wiped away ALL the residue.
3. Taped off he panel with blue masking tape
4. Put on a new, virgin W9207 SoftBuff 2 Finishing Pad that was perfectly clean having NEVER touched anything dirty (emphasis added)
5. Spread #205 over the entire pad to cover it completely.
6. Spread it around and worked it at speed #4 for several slow section passes with moderate pressure. (no progress at all)
7. Applied it again this time on speed 5 and later speed 6
... Pushed it as hard as I could without significantly slowing the pad... Made at least twelve (12) slow section passes.
There is SOME improvement to the swirls and overall the panel looks a bit glossier, but fewer than half the swirls were removed.
What do I do next being this did not get the job done?
I presume I need to get more aggressive with it?
I could not find any M83 from years ago (and even if I did it would be 8 years old)...
What I DO have:
1. I have the Polishing Pads and the Cutting Pads W8207 and W7207 respectively.
2. I have some Ultimate Polish, which I doubt will help (i.e. I feel it M80:M82 as M205:UP am I wrong?)
3. I have SwirlX and ScratchX
4. I have Ultimate Compound and M105
What should I try next with what I have? Should I simply change pads and retry #205? Should I jump to SwirlX or ScratchX OR straight to UC/105???
_______________
What I DO have:
