About to do a complete detail on the car, never done it before....HELP!
  • About to do a complete detail on the car, never done it before....HELP!
    OK so Ive done quite a bit of research on this, but I want to get your opinion on this maybe though.
    Before I do the detailing, I have a few minor dings I need to fix from when I just changed my convertible top. I have the metal ring around the bottom SCRAAAAAPE into my car. Super deep. Im pretty sure I see metal :'(
    Anyway, so I sand that, bondo it, and paint over it. Ive done research on this but not enough to be comfortable with doing it yet. How am I going to blend the paint to make it look like nothing happened? How do I make the bondo look like nothing happened, so its smooth with the car? I know Im going to need to wet sand but how will I not ruin the car?
    Along with the few terrible dings I put in the car with the convertible top, on the front bumper (obviously PLASTIC), the clear coat appears to be cracking, there is a spider crack going out of each end of my BMW Roundel. Should I just touch up paint that too or what should I do with that? Just out of curiosity, what if the clear coat was cracking on a metal surface, what would I do?
    Now to the detailing....
    So first I obviously clean the car, then clay it, then dry it. Firstly, what is your method of drying, Im curious because Ive seen plenty of videos and strategies but I just cant seem to get a good method down. Side note, I did buy a variable speed polisher with 2 foam cutting pads and a wool pad (The wool is for polishing correct? I know thats a dumb question but I cant find anything on the internet about what pads to use when) Next Im going to ultimate compound the car (it probably doesnt need it but Im probably going to do it just this first time to ensure a good job on the car, but I will do a test space with just ultimate polish side by side with ultimate compound to see results), then I will polish the car, then wax it.
    I know I asked a lot, some of it I think is just conformation but like the bondo, I am very worried before I do that because I dont want to make it look worse because of a poor repair job.
    If you can answer any question, that would be great, or if you want to refer me to a different thread/video, thats fine too. Ive done my fair share of research I just really dont want to mess anything up. Im super excited to do this and have my car looking better than ever but Im nervous at the same time!
    Thanks!
    Re: About to do a complete detail on the car, never done it before....HELP!
    First of all, Welcome to MOL!!!
    As far as drying goes, I use my Metro Sidekick and a Dry Me a River towel. The Sidekick does a great job at drying the car and blowing the water out from all the cracks, crevices, around windows, mirrors, tires, rims, etc...after using it, I take my DMAR and wipe off any remaining water that is on the vehicle.
    I had the same issue with the "spiderwebs" on the bottom of my rear bumper, which was also plastic, and I went and had it resprayed.
    Some others will chime in with more info...hope this helps!
      Welcome to MOL!
      Some photos would sure help, but as far as the repairs you described (the deep scratch, and the clear coat cracking) I would take that to be repaired by a professional, especially since it seems you have little to no experience (not saying in a bad way). Those require some pretty advanced techniques and can be easy to stuff up.
      Most people dry with a waffle weave microfiber towel. Meguiar's Water Magnet is a good one. That's the most basic drying method while still being quite safe. There are countless others, and I'm sure others will chime in. BTW you don't actually specifically dry after claying. The car will be dry after you remove your clay lubricant with a MF towel as you go.
      Please tell us more about the polisher you bought - is it a dual action (DA) machine, a rotary, or a wax spreader?
      Other than that, your general process and order of steps seems fine.
        I agree with Davey to have a pro look at the deep scratch and the front bumper. The dings can be easily and relatively inexpensively repaired by a Paintless Dent Repair Tech (... I've seen them work and it's AMAZING!).
        As for detailing the rest of the car, let us know what products and machine you have and we can guide you from there.
        Don
        12/27/2015
        "Darth Camaro"
        2013 Camaro ... triple black
        323 hp V6, 6 speed manual
