My question if I use IronX should I use it before or after I clay bar, or can I skip clay barring if I use IronX? I am working on a White Infiniti G37 Coupe.
Use the baggie test to let you know if you need to clay. I would if it hasn't been done awhile.
In regards to iron x the typical method is applying after a wash. Mike Phillips over at autogeek has a write up where he uses ironx before washing. Stating the dirt will help ironx cling. Then he follows up witha rinse and wash. Saves a little time this way.
