Meguiars White Wax Question
  • Meguiars White Wax Question
    Hey,
    Using my new MT300, I'm going to be using Meguiars white wax on a nice white Mercedes C63 (for a friend) Being synthetic is it ok if some gets on the trim, providing I quickly wipe it off?
    Ultimate Wax claims that is ok to be applied even if the sun is shining. Does the same apply for Meguiars White wax? I live in SW Florida.. It's kinda hard for it to not have sunshine.. not complaining of course.. Could always use my garage. But its always nicer to work in the driveway with a nice gentle breeze as appose to a hot stiffing garage. Even so, even in the garage, the sun hits part of the car at some point. Previously I'd do the front then pull out and turn the car around so that the part i'm waxing is always in the shade.... Ultimate Wax does make my life a LOT easier. No taping off and not sweating so much about if a panel is in the sun...
    Thanks in advance.
    Re: Meguiars White Wax Question
    It's best to avoid the trim all together. It's still carnauba based. Tape off the trim so you avoid more work for yourself. It's best to always work in the shade. You will be ok as long as the panel is not so hot that you can't leave your hand on it. If you work outside just be sure to wipe off the panel of any dust prior to applying product.
    Check out this thread if you have not already done so. Take advantage of the correction power of white wax.
    Follow up with some ultimate quik wax after you buff off white wax to add a tad more protection and shine. You could also top with UW if you want to add something a little longer lasting.
