foam gun
  • #16
    Re: foam gun
    Gold Class will certainly work... just dont expect shaving cream, expect slow moving suds to wipe around the panel.
    I agree with Murr on this. I know it's not a foam gun but I did use Gold Class and D111 with a foam canon and they both behaved the same. Not a lot of foam but still some good suds on the surface. I should have taken a photo. I was using 2 oz.
    • #17
      Re: foam gun
      Is the difference in that the foam gun is used on a regular hose and the foam cannon is to be used on a power washer? I have watched some YouTube videos where people foam cannoned their car and then power washed that off then tow bucket washed. Kind of like a pre wash. Not sure if I would use it like that or use it like Murr mentioned as panel by panel washing. For those of you that have used them, does the soap dry on the car and streak like it can with normal bucket washing?
      • #18
        Foam gun goes on a hose and doesn't really produce the foam like a pw lance gun will. If u have a few xtra bucks the lance is the way to go I think. U can just drench the whole car in foam let it sit and then power wash. Kinda like a ore wash. Or foam it then 2 bucket wash then rinse. I like the idea of carpros snow soap as mentioned earlier for that added decontamination.
        • #19
          Re: foam gun
          Exactly this. Although with me using D111 it is not a high foaming soap like a couple others I have tried. Still decent but nothing to wow anyone. Foam canons are great for showing off and getting your neighbors or passer by's interested
          I found this to save more time than foaming then rinsing then 2 bucket. No need to worry about swirls or scratches since there is so much lubrication (aka soap) on the paint.
          • #20
            Re: foam gun
            This is what I am hoping to gain from it. Even though I am trying really hard to not get scratches and swirls in my black I still can see I am putting them there. I know they are inevitable, but was hoping maybe this might help a little more. I am leaning towards the non power washer option as I don't always like to drag the power washer out every time I wash, especially in the cooler months after I have put it away for the season.
            • #21
              Re: foam gun
              Although, now after spending some time watching some more videos, I am thinking the power washer way is the best way to go. Looks like a lot of people are able to use this to wash a car that is just dusty and not even have to touch a sponge to it with this foaming wash. Just foam and power wash and it cleans ok. Then dry and you are good. That would be good because a lot of times in the summer that is all it is, just dusty or very lightly dirty.
              • #22
                Re: foam gun
                Just be careful because the soap will spot in the sun and heat. Unless you do it early in the morning. In those instances a rinseless would probably be the way to go.
                • #23
                  Yes, the only way I would do that would be early morning or late afternoon early evening. Which had become my routine with the black anyway.
                  • #24
                    Re: foam gun
                    Then you're all set. If I get a chance to bust out the foam canon this weekend, I will snap a photo of using it with Hyper Wash.
                    • #25
                      Guz, which one do you have? You probaly said in all these post. That would be great to see a picture of yours in use.
                      • #26
                        Re: foam gun
                        I have an AR383 that I have had for some time. I picked up an MTM foam cannon during black friday for cheap. I had to buy the foam cannon adapter for it to work with the AR383. You can buy everything from them. It's a decent pressure washer for my personal use.
                        • #27
                          Re: foam gun
                          I have a gas power washer, not sure the brand. Not sure the PSI off hand either. But a decent one. Older, but doesn't get used very often because it is a hassle to get out. MTM seems to be a common one to get. Where did you get yours? Alot of them look like the are MTM with brands on them. Autogeek, Pinnacle, etc.
                          • #28
                            Re: foam gun
                            I got it a surf city garage when they were clearing them out for 1/2 the price. It was too good to pass up. The autogeek one's should be the same. Pinnacle, Detailer's Pro, Wolfgang and Blackfire are their house brands.
                            • #29
                              Re: foam gun
                              top tip - if you're about to clay or if you want to remove the old wax, use common dish soap in your foam gun. Also, don't buy a cheap foam gun! (I did, it ***** and I hate it) The suds from the dish soap make a great lube for claying as well. (I've never tried dish soap with actual clay, I use a nanoskin Autoscrub)
                              • #30
                                Re: foam gun
                                I'm not a fan of using dish soap to strip off old wax. Plus it won't work on most sealants since they are more durable. In addition to that if one is about to polish or cleaner wax then that will strip off any old wax or sealant on the car.
