What should I use for DA unreachable parts of the car? DA Microfiber System Question
  • What should I use for DA unreachable parts of the car? DA Microfiber System Question
    I recently purchased the Meguiars DA Microfiber System 5" as well as 3" backing plate and MF disks. What should I use for DA unreachable parts of the car to complement this system?
    Any suggestion for polish, wax, applicator(s) for these hard to reach by machine areas? I'm thinking maybe Meguiars 105 & 205. Example: inside of BMW M3 mirrors, door handle recessed section, and other hard to reach areas. (see pics)
    Thanks in advance.
    Re: What should I use for DA unreachable parts of the car? DA Microfiber System Quest
    3" or 4" foam pads will work.
      By hand is the way to go for those hard to reach areas. I use these pads
      CCS Euro Foam Hand Polish Applicators - Use foam buffing pad technology without using a buffer! The CCS Euro Foam Polish Applicators allow you to match polishes to the appropriate foam variety, just as youd do if you were applying the products with ...
      As far which recommended products to use. Well what products do you own? The D300 that comes in the DAMF system should work. Other compounds that work well are ultimate compound and M105. They will all get the job done. For a polish ultimate polish or M205 would be the way to go. The DAMF system comes with D301 which is a cleaner wax. It should give you about 2-3 months of protection. If you are looking for a longer lasting wax then a synthetic lik NXT or ultimate wax would be what you are looking for. You can also add a coat of either synthetic depending after using the DAMF system. Just allow a 12-24 hour window before applying.
        Agree with the Guz, by hand is the easiest for me too.
          I do tight areas with 4in pads, and REALLY tight areas by hand.
