Ult-Wash & Wax - Marks on paintwork ?
  • Ult-Wash & Wax - Marks on paintwork ?
    Hi guys.
    Ive recently bought a brand new VW Golf GTI, and proceeded to buy the whole range of Megs product, including the Ultimate Wash and Wax.
    Now, for some reason, after washing and drying the car with a drying towel, there seems to be a lot of excess white marks all over the whole car. They look like dried water.
    To remove this I have to go over the whole car again with a microfibre cloth to clean all the excess, which looks to be dried wax ?
    Am I doing some wrong ?
    Should I be using this product on a new car ?
    Any info would be much appreciated.
    Rich.
    Btw, here is the new car
    Re: Ult-Wash & Wax - Marks on paintwork ?
    Any ideas guys ?
      I have never had an issue with this soap. Are you using the proper mix to water? I believe it is 1 ounce per 1 gallon. It could be that you are using too much soap in your mixture. Are you also washing in the shade or in direct sun?
      Also it sounds like you are removing any excess soap residue with just a dry micrfiber. I would recommend you use some detail spray to remove the excess. Rubbing a dry microfiber on the paint can casue scratches.
      I like to use either ultimate quik detailer or ultimate quik wax after drying my car.
      A good washing reference video in in this thread.
      Meguiar's Quik Tips Video Series - Washing After viewing the video clip you can scroll down for a step by step refresher, complete with still images shot during the filming of the video. <object width="640" height="385"><param name="movie" value="http://www.youtube.com/v/SVcVpS0
        Yeah, in the long run, Gold Class soap and drying with Ult. Quick Wax is probably the better combo...
        But have not heard of that issue.
        How long is the soap drying on the paint for?
          How do you know it's the UWW?
          Is there any wax / sealant / coating on the paint prior to you washing it?
          What's your exact washing / drying technique? Are you rinsing the UWW off?
            http://www.meguiarsonline.com/forums...Series-Washing
            Cheers for the link
            Yep, mixture is spot on.
            I'll stay clear of using a micro fibre for now then just in case.
            I immediately rinse the soap off once I've finished washing the car, and its dried off with a drying towel.
            Yeah I might use the Gold class next and see what results I get.
            The paint was ceramic coated from the dealers, but they said cleaning it shouldn't be an issue ?
            Shall I use a wax free wash ?
              what was your washing method? in the mid day sun? What you are describing "sounds" like mineral deposits from water drying. The wax in the soap is minimal and is more of a gloss enhancing agent than a stand alone wax, therefore it alone doesnt leave a waxy film unless it was glooped onto the car.... which im sure you didnt do!
              I would suggest washing your vehicle in the early morning or last hour before sunset-- both are the absence of sun and heat from the car. Its nice and peaceful and you can have the time all to yourself if youre up early enough!
              Also, i recommend using a drying medium that is SUPER absorbent and plush so that in case you come over a region that was missed in the washing process it can more safely pick up any dirt particles.
              I think the above combination would prove to be useful in solving the problem.
              ALSO, if washing without a pressure washer on the finish rinse, REMOVE any attachment and let the water flow out at a medium rate and use the water to FLOOD the car, attempting to keep the water together as much as possible. Start and the top and work down the sides. In doing this, the water wants to stay together to maximize its surface with the smallest surface area-- meaning it likes to stay with other water molecules. So in the end there is much less water on the car that needs removal and the paint is touched less.... you will dry the car faster and easier due to less to remove..
              Hope these help--- welcome to the fun zone
              Christopher Brown | OCDCarCare Los Angeles - Auto Detailing Services & Training Courses
              OCDCarCare.com | FACEBOOK| Detailing Article Archive | INSTAGRAM
              2013 Meguiar's/Ford SEMA Team, 2015 SEMA Car Crazy Corral
