Prep wheels for Opti-coat 2.0
  • Prep wheels for Opti-coat 2.0
    I'm buying a set of used chrome wheels with tires mounted. I want to protect them with OC 2.0.
    My prep will be:
    -Wash and dry
    -Clay Bar
    -Polish with Meg's wheel polishing kit (connected to a drill)
    -Wipe with an Acid neutralizer
    -Wipe with denatured alcohol to remove any residue
    -Apply OC 2.0 to the outside and inside of the wheel. (should I dismount the tire and apply OC 2.0 in there too?)
    Does this sound like a good procedure so OC 2.0 bonds correctly?
    Re: Prep wheels for Opti-coat 2.0
    I have never worked with opti coat but I would do the insides of the wheels as well.
      What is the acid neutralizer for? Just curious, as I'm not sure that's required.
      Personally I think taking the tires off is overkill, but yeah definitely do the barrels. Everything else looks fine.
        Acid neutralizer is to neutralize any acid that the polish may have left behind. I have Everbrite Protectaclear left over from an old project. Might just paint it on instead of ordering opticoat.
          I am stripping some failed clearcoat off my motorize crankcase covers was thinking of using Protectaclear. Were you happy with the Protectaclear?
            It's ok. It's very sensitive to chemicals- I sprayed a wheel cleaner on a test spot and it clouded the Protectaclear. It's good stuff though bc you can just reapply whenever you want and it is self annealing. So in this case I touched it up and it looked ok again. If it wears off next
            winter, I'll apply OC2.0.
              Thanks for the feedback. How long has the Protectaclear been on?
              Do you think the OC2.0 will provide a more protective coating?
                It has been on for about 3-4 months. I think OC would provide a more fool proof coating and look better and last longer. That's just my opinion though.
                  Just to add, Protectaclear is thicker than OC, so it depends on your application. I may end up staying with it if it holds up well enough next winter since I can just reapply to scratched/worn areas, whereas OC will need a light scuffing before you can reapply. Protectaclear is also noticeable to the trained eye so you can see where you missed, whereas OC is undetectable- which is also a good thing appearance wise. Don't get me wrong, my wheels look great, but I can tell the coating is on there.
                    Thanks again - good feedback. Originally I was just going to keep polishing the covers after I stripped - but then I read some are using Sharkhide, some Protectaclear, some ShineSeal (Zoop), and now some are trying OC to put a protective layer over the polished chrome. I am not planning on polishing to a chrome like finish - but do need to polish out some waterspots after I remove the clearcoat. The Protectaclear is certainly a lot less money.
