I was unable to wax my RV for about 1 1/2 years and it is stored outside. The paint from the beltline down is bright and shinny, however the white paint on the upper half was showing signs of the suns UV rays and it did not shine anymore. There are a number different decals on the sides and the decals looked dirty.
I buffed the white painted areas on the upper half and returned them to where I can see object's reflecting in the paint.
My problem is whenever the buffing pad touches the decals it blackens the buffing pad and leaves black marks on the white paint. The black marks do not wipe off the paint. The only way to remove them is to use some of the polishing compound on the paint again. I noticed that areas on the decals where the buffing pad did overlap them seemed to clean up a fair amount. Unfortunately the pad quickly turned black.
The decals are in good shape, solidly adhered to the paint and the surfaces are as smooth as the paint. I tried some of the buffing compound on a rag to see if that would clean the decals. The result was that the rag turned black very quickly and became unusable. I assume that using clay would not end successfully.
Do you have any suggestion how to clean up the decals?
Which Maguiars products will provide the best protection against this problem reoccurring.
