Nanoskin vs Speedy Prep Towels
  • Nanoskin vs Speedy Prep Towels
    Is there a noticeable difference between the two? I am looking at getting one of these this spring and to me they look to be darn near identical. I'm thinking of going with the fine grade of which ever I end up getting. I think that should be more than adequate for my needs unless someone has experience with these towels and can recommend medium over fine grade as well. Also can you use these as you wash or do you want to use them after a wash with a lube as you would clay. If you can use it as you wash I was thinking of washing a panel, rinsing and soaping up the panel with fresh soap. Thank you for any and all input!
    Re: Nanoskin vs Speedy Prep Towels
    I believe both are made by the same parent company?
    I have both brands and both grades....I haven't used the med grade yet. The feel appears to be the same (Nano Vs Speedy)
    I cannot see myself using regular clay ever again, but i do have a few bars in my inventory just in case I need it.
    I think the nanoskin wash mitt was designed to wash & clay, but I'd recommend a 2 bucket method.
    I personally prefer to do a traditonal wash before claying/or nanoskining/clay towelin
    i recommend checking out Amazon for good prices on Nanoskin products...lotsa reviews too
    http://www.amazon.com/s/ref=nb_sb_ss...os%2Caps%2C302
    "STRIFE" aka Phil
      I have both and use both. I like the wash mitt, my process is rinse, foam, rinse, wash, and then nanoskin wash mitt with soap and water. I use speedy prep when water is an issue with Megs LT/DS. I keep clay around for those tight to reach areas.
        I use both of them. the DA one can't get into the nooks and crannys like the towel.
        Also I use them as I wash with no problems.
        DetailingByM.com
