Headlights
  • Headlights
    Had this posted in an old thread and wasn't getting many views so I moved it here.
    Need some help...what do you all see in this pic of my headlight? I've hit it with UC and rotary and cutting pad, not really getting any better. I have researched extensively on this site for headlight restoration. As someone mentioned on other thread, does this look like deteriorated plastic? Don't wantt o waste my time polishing if it's unpolishable. Thanks
    Re: Headlights
    Those need to be sanded down, compounded polished then coated.
    Thoryamaha919 AKA Evan
      Re: Headlights
      Here is a pair of headlights I did yesterday
      We encourage MOL members to show off their latest before & after results. We also welcome "Work in Progress" Threads. For Enthusiasts or Professional Detailers
        Re: Headlights
        alright, I'll get the headlight kit then. Thanks!
          Re: Headlights
          How smooth do they feel now? Can you feel any edges where the coating is failing?
            They feel pretty smooth. Can't feel any edges.
              I'm going to have to agree with Evan. The coating looks like its started to come off. I just used the heavy duty restoration kit and it worked good. But instead of using plastx I used the sanding discs, M105/M205 on my DA with 4" pads and then followed that with the sealant provided in the kit. The provided sealant would need to be applied evert 6-8 weeks. If you want a permanent fix you can reclear coat them or use something like opti-coat the headlight kit version.
              99 Grand Prix
              02 Camaro SS
                Re: Headlights
                Good stuff there Guz. Thats what I do except I use Opti-lens which has the UV coating you need for the protection regular opti-coat does not. When you sand down the lens you remove to UV coating so you need something that will have the UV protection in it and that what Opti-lens has and its great.
                  Re: Headlights
                  Thanks. I couldn't rememner the name off the top of my head. I knew someone would chime in with the right one.
                  99 Grand Prix
                  02 Camaro SS
                    Re: Headlights
                    sand, polish, re-paint
                    Headlight Renew Dr.
                    http://headlightrenewdoctor.com/Products.php
                    DetailingByM.com
                      Re: Headlights
                      wow...excellent tips there everyone! Think i'll get the headlight kit, will try to put up an after pic. Thanks everybody!
                        Re: Headlights
                        I used PlastX by hand a few times and it never worked for me. I did rub very hard each and single time.
                        I am thinking to get the Meguiars headlight kit and have to decide to get the regular one or the heavy duty one.
                          Headlight Restoration Process
                          Sand with 1500 grit (use soap/water), then with 2000 grit. Buff out with 105 using wool then medium pad. Finish with black pad and plastic-x....... see http://www.joscratch.com/2000vwjettaheadlightrestoration.html for pics
