HOw to Care for MIcrofiber Towels
  • HOw to Care for MIcrofiber Towels
    Ok I am going to invest in some really good polishing towels and I want them to last a long time.
    Here is what I have learned so far
    1) No fabric softner
    2) NO Bleach
    3) Dry on low heat or no heat.
    The only question I have is what detergent to use? Should I use a dedicated wash detergent for cleaning my microfiber towels
    Would it be ok to use detergents similar to these no dye or perfume detergents "Tide Free & Gentle" or "Wisk Free & Pure"
    From my experience so far, with all of my microfibers, I will use a dedicated microfiber cleaner. I just picked up a bottle of the Pinnacle microfiber detergent from Auto Geek. I had used regular bleach free detergent in the past and it never seemed to really be "bleach free", as the towels would lose some color and that static cling feel. Just my experience though.
    As for the fabric softener, definitely stay away from that. I had a batch of towels get mixed with someomes laundry and afterwards they were only good for the garbage can.
    I also don't like to put my towels in the dryer, even on low heat. But lots of people say it's fine. I guess my dryer just runs a little warm for my taste. I let them air dry before I fold and put away.
    Everybody digs a nice clean car.
      Re: HOw to Care for MIcrofiber Towels
      I use Micro-Restore exclusively on all of my MF towels, worked great with warm water in my washing machine. On particularly soiled towels, I let them soak overnight before washing.
      I know a lotta guys here also use a cup of vinegar on the final rinse....
      Micro-Restore Microfiber Detergent Concentrate 128 oz. - The only detergent properly formulated for maintaining and restoring microfibers. Yes, microfibers are machine washable. Completely. But the truth of the matter, is that with all of the ...
      "STRIFE" aka Phil
        USe All free and clear.. no dyes or perfumes...
        use HOT water and allow soap to mix and then soak for at least 60 min.....[periodically i soak oer night in BOILING water to remove all embedded filth and grime]
        i also add a 1/2 cup of APC to the mixture
        on final rinse add 1/2 cup vinegar...
        dry on medium to low heat
        ___________________________
        also an important point not often made clear is to wash like towels with one another
        ww MF towels with other lightly soiled.. medium with medium.. heavily soiled with heavy
        or compouning and polishingg towels with one another...
        dont mix wax mf with polishing MF with greasy MF
        Christopher Brown | OCDCarCare Los Angeles - Auto Detailing Services & Training Courses
        OCDCarCare.com | FACEBOOK| Detailing Article Archive | INSTAGRAM
        2013 Meguiar's/Ford SEMA Team, 2015 SEMA Car Crazy Corral
          To add to the diversity of opinion, I do the following:
          - Splash pads with a little MF cleaner and wash in hot water with towels and Tide Free (sometimes I add a little MF cleaner to the wash cycle);
          - Finish wash rinse spin cycles;
          - +/-1/2 cup vinegar in wash cycle, complete full wash rinse spin;
          - Toss in dryer with 2 blue balls (helps eliminate static
          I don't worry about mixing products (wax, polish, express wash, QD, etc.) BUT WHEN I use full synthetic wax, I usually soak those pads and towels in MF cleaner and water overnight, then rinse and squeeze very well. I have M21 and it's tough to get out of pads. Don't use it often though.
          2018 Acura RLX Tech - Majestic Black Pearl
            Just to add to the confusion ... I sort my MF: Wash and drying ones go in one load; polish and wax ones go in another. Wash in warm water and Purex. Rinse in warm water. Final rinse in cold water and a bit of white vinegar. I do it all by hand (wife does NOT want wax in her washer and dryer!).
              I'm with STRIFE on this one, except I spray oxy-clean on troublesome spots before machine washing with MicroRestore and rinse with white vinegar. Those used for glass are done separately. Pads get soaked and hand cleaned in Snappy before getting machine washed in MicroRestore.
              David
                I also hand wash all pads
                  My towels get machine washed in hot water and a good quality laundry detergent. I dry them on medium heat - sometimes with a dryer sheet, and sometimes without. I think it's best for the towels *not* to be dried with a dryer sheet because it seems to me that dryer sheet residue can clog up the towels to a certain extent.
                  White vinegar (in the rinse cycle) removes detergent residue from the towels.
                  r. b.
                    Do not wash in hot water.
                    You'll melt the MFs. wash in warm only. (read the lable)
                    Use any detergent.
                    Vintager removes "grease" and opens the MFs
                    No "softeners", it leaves a residue on the MFs
                    DetailingByM.com
                      Use any detergent.
                      Seems to me that it would take boiling hot water to melt synthetic fibers, but I have not read any labels of late (I tore them off).
                      Did the label mention a specific water temperature (in degrees) to avoid?
                      r. b.
                        Typical hot water heater setting is 120-130 F. Typical laundry dryer high temps max out at 250 F.
                        I think my black on black vehicle gets somewhere in between the two on a sunny summer day.
                        The 428 F (220 C) melting point of (polyamide) nylon 6 (BASF) is lower than the 509 F (265 C) melting point of (polyamide) nylon 6,6 (DuPont).
                        Polyester melting point is about 490 F.
                          Thanks.
                          r. b.
                            my bag had a cut in it and I wanted to get close ups of the instructions for you so 2 pics
                            DetailingByM.com
                              Found this from an MF wholesaler:
                              Machine Washing Microfiber:Wash in warm or hot water with mild detergent. Do not use fabric softener, it will clog the open spaces in the microfiber that do the cleaning rendering the towel or mop useless. Microfiber tends to grab a hold of lint in the wash just like it grabs dirt and dust when you’re using it to clean. With this in mind be careful of what you wash microfiber with. Avoid washing it with anything made of cotton especially terry cloth towels, socks etc. Ideally you should wash microfiber only with other microfiber, but if you need to mix loads wash it with other non-linting synthetic materials.
                              Hand Washing Microfiber:Wash in hot water with mild detergent, use a soft bristled brush if necessary. Rinse thoroughly.
                              Drying Microfiber:Air drying microfiber will make it last the longest. Microfiber dries relatively quickly. If you choose to dry your microfiber in a dryer do so on low heat or no heat and only dry with other microfiber products to prevent the mops or towels from picking up lint. Microfiber will grab a hold of any lint given off by other items in your dryer if they are dried with anything else that lints.
                              Commercial Laundering Instructions for Microfiber:The following are the instructions and wash formula that will assure maximum performance and longevity.
                              Detergent: High solvent for heavy soil. No Alkaline. Dose determined by product specifications for poundage.
                              No bleach, no fabric softener.
                              Operation Time Water Temp Water Level
                              Flush 2 Min 120 F High
                              Flush 2 Min 140 F High
                              Suds 25 Min 160 F Low
                              Rinse/Extract 3 Min 140 F High
                              Rinse/Extract 2 Min 80 F High
                              Rinse 2 Min 80 F High
                              Extract 6 Min
                              Commercial Drying Options:
                              Option One: Tumble dry: Maximum temperature 140f NOTE: Air Dry is preferred to double life.
