foaming trigger sprayer
  • foaming trigger sprayer
    I got the SM arnold foaming trigger sprayer (yellow/white)
    http://www.detailing.com/store/sm-arnold-foamer-trigger-sprayer-3-5-ml-stroke-yellow.html
    I just used it today with the Meguiar's APC 4:1.
    I was just wondering if it is suppose to produce alot of white foam? Cause it feels a bit watery to me.
    Unless I didn't adjust the tip correctly. Anyone know if turning the tip so that the tip is further away would make more foam?
    Re: foaming trigger sprayer
    Some products will foam more than others when used with a foaming sprayer, but you really hit the big variable - how you adjust the sprayer. That can and will have a large impact on just how much foam you produce with any product. APC should be able to produce a decent amount of foam with this sprayer, so play around with the adjustments a bit and you'll hit on the right set up for you.
