S3BP and W68DA Can be used with Dual Action G110(Not G110v2)?????
  • S3BP and W68DA Can be used with Dual Action G110(Not G110v2)?????
    Good day....I have a question...... Can I use S3BP and W68DA Backing pads with my actual DA Polisher G110????? And I mean G110 and not G110v2......Thank you for your answer and help because with this I'll know if I buy these accessories or not.....Have good day.....
    Yes you can. All dual action polisher backing plates (S3BP, W67DA, W68DA, S6BP or other manufacturer's backing plates) are interchangeable and will mount to any dual action polisher available in the market. This includes your G110. Heck, it will also work with the G100.
    Hope this helps.
      Re: S3BP and W68DA Can be used with Dual Action G110(Not G110v2)?????
      Great!!! With this I can do my projets with my polisher....Thank you again for your help Marc08EX...........I hope to see you again and help you too...
        You are very welcome. If you have any other questions, pls don't hesitate to ask.
          I just want to add that the Flex 3401 forced rotation dual action polisher is the exception to this. This is because the 3401 uses a direct drive mechanism as opposed to the free floating spindle.
            And that's better???? I mean the polisher Flex???
              And as last question.....S3BP Backing pad can be too used with a rotary polisher like Bosch GP712VS or I need to buy w63 backing pad???
                The S3BP or any dual action polisher backing plate can only be used for dual action polishers. You need to get the rotary backing plate for rotary polishers.
                The DA backing plates have a male type of screw attachment while the rotary backing plates are female type.
                  Perfect...Then with this information I know what to do.......I'll see you later and thanks again.....
